I saw in an older post that it is possible to configure imagePullSecrets for private repos - for dockerhub for example.
The docker method doesn’t seem to be supported in K8s:
docker-registry-username: your_docker_username
docker-registry-password: your_docker_token
docker-registry-domain: docker.io
What is the correct way to add a reference to a docker secret to the SP operator for Kubernetes?
Thank you!
Answer: the syntax is image-pull-secret. If you are using an overlay example, simply go to resources/shinyproxy.shinyproxy.yaml and add your docker secret under proxy > kubernetes.
