I would like to know if you have what should be the minimum characteristics of a server to use shiny proxy with docker.
Hi @andalo86,
Shinyproxy itself is a fairly small Java application that can run with just 1 CPU and 50MB RAM.
But the true system requirements will depend on the nature of your Shiny app, and how many concurrent users you want to serve.
More info is geven here: https://www.shinyproxy.io/getting-started/
