I an facing an issue with the kubernetes pod deployment patching.
I am trying to patch the pod manifest deployed by shinyproxy 2.6.0.
My app configuration looks like that :
kubernetes-pod-patches: |
- op: add
path: /spec/securityContext
value:
runAsUser: 65534
runAsGroup: 65534
fsGroup: 65534
- op: add
path: /spec/containers/0/securityContext
value:
privileged: false
readOnlyRootFilesystem: false
runAsNonRoot: true
runAsUser: 65534
capabilities:
drop:
- KILL
- MKNOD
- SYS_CHROOT
- NET_RAW
- op: add
path: /spec/containers/0/startupProbe
value:
httpGet:
path: "/"
port: 80
scheme: "HTTP"
initialDelaySeconds: 5
failureThreshold: 3
- op: add
path: /spec/containers/0/livenessProbe
value:
httpGet:
path: "/"
port: 80
scheme: "HTTP"
failureThreshold: 3
I have enabled the kubernetes.debug-patches to see what is going on and i see :
spec:
containers:
image: “xxxxxx”
imagePullPolicy: “Always”
livenessProbe:
failureThreshold: 3
httpGet:
path: “/”
port: “80”
scheme: “HTTP”
securityContext:
capabilities:
drop:
- “KILL”
- “MKNOD”
- “SYS_CHROOT”
- “NET_RAW”
privileged: false
runAsNonRoot: true
runAsUser: 65534
startupProbe:
httpGet:
path: “/”
port: 80
scheme: “HTTP”
failureThreshold: 3
So the Kubernetes API do not want to deploy that manifests saying that :
Caused by: io.fabric8.kubernetes.client.KubernetesClientException: Failure executing: POST at: https://kubernetes.default.svc.cluster.local/api/v1/namespaces/rshiny/pods. Message: Pod “sp-pod-e8fcb447-0561-4d49-bbbc-7b51ef52d741” is invalid: spec.containers[0].livenessProbe.httpGet.port: Invalid value: “80”: must contain at least one letter (a-z). Received status: Status(apiVersion=v1, code=422, details=StatusDetails(causes=[StatusCause(field=spec.containers[0].livenessProbe.httpGet.port, message=Invalid value: “80”: must contain at least one letter (a-z), reason=FieldValueInvalid, additionalProperties={})], group=null, kind=Pod, name=sp-pod-e8fcb447-0561-4d49-bbbc-7b51ef52d741, retryAfterSeconds=null, uid=null, additionalProperties={}), kind=Status, message=Pod “sp-pod-e8fcb447-0561-4d49-bbbc-7b51ef52d741” is invalid: spec.containers[0].livenessProbe.httpGet.port: Invalid value: “80”: must contain at least one letter (a-z), metadata=ListMeta(_continue=null, resourceVersion=null, selfLink=null, additionalProperties={}), reason=Invalid, status=Failure, additionalProperties={}).
The issue is that the port of the livenessProbe is “80” with doubles quotes so considered by Kubernetes like a string and not an int.
I do not understand why this does no occur for startupProbe which is the first to be patched. It would be the issue would occur for the second probe in the kubernetes-pod-patches list.
I an unsure what to do. I have tried a lot of things to bypass that behavior but nothing seems to work. Any help would be really appreciated.
