We are attempting to authenticate Shinyproxy via Azure SAML SSO with not much luck. Do I need to use the ngx_http_auth_request_module? The Azure example on the Configuration doc only has role-based authorization.
My experience with the SAML SSO and ShinyProxy is that the instructions need to be followed to a T, otherwise you get all kinds of weird SpringBoot errors. Including signing certs, no importing they have to be generated and stored in the JKS store. I don’t know about with Azure though.
What IDP did you use to get SAML SSO working? Auth0?
I don’t really know the IDP team gave me a URL, could be SiteMinder.
