hello all,
running nginx+shinyproxy, box is tightened, but unencrypted 9090 is a thorn. any way to disable (do not need monitoring) or at least restrict to 127.0.0.1?
Thank you.
Porksy
hello all,
Thank you.
Porksy
Hi, you can force it to only listen on 127.0.0.1 using:
management:
address: 127.0.0.1
