I have deployed Rdepot using Docker Compose following the official documentation, but I am encountering an authentication issue.
I organized my configuration files as follows:
├── docker
│ └── compose
│ ├── backend
│ │ └── application.yaml
│ ├── proxy
│ │ ├── nginx.conf
│ │ └── rdepot.conf
│ └── repo
└── docker-compose.yml
generated with :
wget -O docker/compose/proxy/nginx.conf https://raw.githubusercontent.com/openanalytics/RDepot/refs/tags/v2.5.0/docker/compose/proxy/nginx.conf
wget -O docker/compose/proxy/rdepot.conf https://raw.githubusercontent.com/openanalytics/RDepot/refs/tags/v2.5.0/docker/compose/proxy/rdepot.conf
wget -O docker/compose/backend/application.yaml https://raw.githubusercontent.com/openanalytics/RDepot/refs/tags/v2.5.0/docker/compose/backend/application.yaml
wget -O docker/compose/repo/application.yaml https://raw.githubusercontent.com/openanalytics/RDepot/refs/tags/v2.5.0/docker/compose/repo/application.yaml
- The
docker-compose.ymlfile is located at the root and is identical to the one provided in the documentation.
services:
image: nginx:alpine
container_name: oa-rdepot-proxy
restart: unless-stopped
volumes:
- ./docker/compose/proxy/nginx.conf:/etc/nginx/nginx.conf:ro
- ./docker/compose/proxy/rdepot.conf:/etc/nginx/sites-enabled/rdepot:ro
- repository:/opt/rdepot/repo/:ro
- logs:/var/log/nginx/
ports:
- ${RDEPOT_PORT:-80}:80
depends_on:
- backend
- repo
- frontend
networks:
- oa-rdepot
db:
image: postgres:alpine
hostname: oa-rdepot-db
container_name: oa-rdepot-db
environment:
- POSTGRES_DB=rdepot
- POSTGRES_USER=rdepot
- POSTGRES_PASSWORD=mysecretpassword
networks:
- oa-rdepot
backend:
image: openanalytics/rdepot-app:2.5.0
hostname: oa-rdepot-backend
container_name: oa-rdepot-backend
volumes:
- repositories:/opt/rdepot/repositories/
- snapshots:/opt/rdepot/generated/
- queue:/opt/rdepot/new/
- ./docker/compose/backend/application.yaml:/opt/rdepot/application.yml
networks:
- oa-rdepot
depends_on:
- db
environment:
- DB_URL=jdbc:postgresql://oa-rdepot-db:5432/rdepot
- DB_USERNAME=rdepot
- DB_PASSWORD=mysecretpassword
- ALLOWED-ORIGIN=http://localhost:${RDEPOT_PORT:-80}
healthcheck:
test: ["CMD-SHELL", "if [ \"$$(curl -I localhost:8080 2>/dev/null | grep HTTP/1.1 | cut -d\" \" -f2)\" != \"302\" ]; then exit 1; else exit 0; fi;"]
interval: 10s
timeout: 10s
retries: 10
repo:
image: openanalytics/rdepot-repo:2.5.0
hostname: oa-rdepot-repo
container_name: oa-rdepot-repo
volumes:
- ./docker/compose/repo/application.yaml:/opt/repo/application.yml
networks:
- oa-rdepot
frontend:
container_name: oa-rdepot-frontend
image: openanalytics/rdepot-client:2.5.0
networks:
- oa-rdepot
environment:
- VITE_LOGIN_SIMPLE=true
- VITE_LOGIN_OIDC=false
- VITE_URL_PREFIX=/
- VITE_SERVER_ADDRESS=http://localhost:${RDEPOT_PORT:-80}/backend
networks:
oa-rdepot:
volumes:
repository:
repositories:
snapshots:
queue:
logs:
- I have enabled simple authentication by setting the environment variable:
VITE_LOGIN_SIMPLE=true - I also tested using the “none” authentication mode, but the issue persists.
The Issue
When clicking the login button, a popup appears with the following error message:
- unsuccessful login
- there seems to be a configuration issue in the backen. please contact your administrator to fix this.
I attempted to log in using the credentials:
einstein/testpassowrdtesla/testpassword
Additionally, I enabled verbose logging in the backend configuration by adding the following to the logging configuration:
rdepot.log
level:
root: DEBUG
When I click the login button, the backend container (oa-rdepot-backend) logs the following error:
2025-02-06 10:58:18.800 89973 [http-nio-8080-exec-10] DEBUG traceId= o.a.c.h.Http11Processor : Error parsing HTTP request header
java.io.EOFException: null
at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.fillReadBuffer(NioEndpoint.java:1288)
at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.read(NioEndpoint.java:1176)
at org.apache.coyote.http11.Http11InputBuffer.fill(Http11InputBuffer.java:785)
at org.apache.coyote.http11.Http11InputBuffer.parseRequestLine(Http11InputBuffer.java:348)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:264)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:896)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1736)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
at java.base/java.lang.Thread.run(Thread.java:840)
2025-02-06 10:58:18.800 89973 [http-nio-8080-exec-10] DEBUG traceId= o.a.c.h.Http11Processor : Error state [CLOSE_CONNECTION_NOW] reported while processing request
The EOFException appears when I click the login button and seems to occur sporadically at other times as well.
- I am testing Rdepot on a dedicated server available at: http://57.129.133.107/.
- I have followed the documentation as closely as possible.
- I am unsure if I am missing any configuration steps or if this is a known issue with the current setup.
Are there specific configuration parameters in the backend’s application.yaml or elsewhere that I should verify or adjust to resolve this issue?
Are there additional logs or debugging steps you recommend to further diagnose the problem?
I appreciate your assistance in troubleshooting this matter. Please let me know if you need any additional information or logs.
Thank you for your support.
Best regards,
Vincent
