I have developed a solution and decided to use shinyproxy.
I have the following problem:
A user needs to capture data on the solution, which must be stored and updated on the database for all users accessing the solution, I used SQLite and with R for this.
Now when I log in and capture data, it saves, but when i log in with a different user I dont get to find the captured data.
The problem is that saving data doesnt seem to be saving on the docker image, why is this and how can I go about remedying it?
For problem testing purposes:
Solution link: https://www.oisbotash.com
Data Capturer user:
username: dispatchclerkB@botash.co.za
password: Fyyds7zF.
Admin user:
username: info@qnum.co.za
password: prupre35A2.
Testing:
Inside the solution, if you go to the data management tab, data entry and then right click on an table and insert a new row, click save changes, it must safe new changes to the docker image but its only temporarily doing so, the other user cant see the changes made.
My solution is going live Wednesday 18 July 2018.
Your assistance would be greatly appreciated as this is critical.
