Dear Community,
I have latest version of java installed but for some reason I could not install shinyproxy
$ java -version
openjdk version "15.0.2" 2021-01-19
OpenJDK Runtime Environment Zulu15.29+15-CA (build 15.0.2+7)
OpenJDK 64-Bit Server VM Zulu15.29+15-CA (build 15.0.2+7, mixed mode, sharing)
$ sudo rpm -i shinyproxy_2.4.3_x86_64.rpm
error: Failed dependencies:
java-openjdk is needed by shinyproxy-2.4.3-1.x86_64
running CentOS Stream 8
I installed java versions 15.x, 11.x, 8.x from dnf (and yum) but same error message appears.
any help will be appreciated!
thanks
