Is there a way to add a keyboard shortcut to Architect for the dplyr/magrittr pipe function %>% ? Something similar to the Insert Assignment Operator that is bound to Ctrl+< and Ctrl+=
It seemed like there should be a way to do it, but I haven’t been able to figure it out. I also tried installing the Eclipse plugin PracticallyMacro which would provide a similar capability, but it doesn’t install correctly through the marketplace, and my attempts to install manually haven’t worked either.
Any ideas?
–K1W
