I have this problem. After click Login in, the browser shows this message “Can’t reach this page”. This is the log:
2019-02-06 13:36:16.820 ERROR 1 — [XNIO-2 task-3] o.k.adapters.OAuthRequestAuthenticator : failed to turn code into token
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[na:1.8.0_181]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[na:1.8.0_181]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[na:1.8.0_181]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[na:1.8.0_181]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[na:1.8.0_181]
at java.net.Socket.connect(Socket.java:589) ~[na:1.8.0_181]
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:121) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:180) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:144) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:134) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:610) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:445) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:835) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56) ~[httpclient-4.5.5.jar!/:4.5.5]
at org.keycloak.adapters.ServerRequest.invokeAccessCodeToToken(ServerRequest.java:111) ~[keycloak-adapter-core-4.7.0.Final.jar!/:4.7.0.Final]
at org.keycloak.adapters.OAuthRequestAuthenticator.resolveCode(OAuthRequestAuthenticator.java:335) [keycloak-adapter-core-4.7.0.Final.jar!/:4.7.0.Final]
at org.keycloak.adapters.OAuthRequestAuthenticator.authenticate(OAuthRequestAuthenticator.java:280) [keycloak-adapter-core-4.7.0.Final.jar!/:4.7.0.Final]
at org.keycloak.adapters.RequestAuthenticator.authenticate(RequestAuthenticator.java:139) [keycloak-adapter-core-4.7.0.Final.jar!/:4.7.0.Final]
at org.keycloak.adapters.springsecurity.filter.KeycloakAuthenticationProcessingFilter.attemptAuthentication(KeycloakAuthenticationProcessingFilter.java:149) [keycloak-spring-security-adapter-4.7.0.Final.jar!/:4.7.0.Final]
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:212) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.keycloak.adapters.springsecurity.filter.KeycloakPreAuthActionsFilter.doFilter(KeycloakPreAuthActionsFilter.java:86) [keycloak-spring-security-adapter-4.7.0.Final.jar!/:4.7.0.Final]
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178) [spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357) [spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270) [spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99) [spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:109) [spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:81) [spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200) [spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:64) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:94) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at eu.openanalytics.containerproxy.ContainerProxyApplication$ProtectedPathHandler.handleRequest(ContainerProxyApplication.java:111) [containerproxy-0.7.0.jar!/:0.7.0]
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:336) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [na:1.8.0_181]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [na:1.8.0_181]
at java.lang.Thread.run(Thread.java:748) [na:1.8.0_181]
