I have a configuration as
container-env:
SHINYPROXY_EMAIL_ID: “#{keycloakUser.keycloakSecurityContext.token.email}”
it was working fine till sometime but now the pods do not have the environment variable. I am not sure what has changed and how to debug it. can anyone help me?
The settings seems correct to me. Can you check the following things:
- check whether an e-mail address is set for this user in Keycloak
- check whether keycloak passes the e-mail address of the user to ShinyProxy. Go to the client in the Keycloak admin interface. Click on
Client Scopes
, click theevaluate
tab, select a user and click theEvaluate
button. Next check whether access token and id token contain an email claim.
Which keycloak and shinyproxy version are you using?
