Hi all,
I recently deployed Shinyproxy Operator on DigitalOcean (using the 1-namespaced-hpa example). Now I want to add my customized HTML template, but I cannot seem to get the correct path.
I tried:
- using the default path (e.g., template-path: ./templates/2col). (root dir = location of shinyproxy.yaml)
- using the root directory of kustomization.yaml in 1-namespaced-hpa (e.g., template-path: ./shinyproxy/templates/2col)
- using the root directory of the deployment (e.g., template-path: ./overlays/1-namespaced-hpa/shinyproxy/templates/2col)
- exporting the theme to github and call the raw index.
All attempts did not result in any changes to the login page, while this template previously worked on my stand-alone shinyproxy instance.
Am I missing some Kubernetes magic to add these files? Do I need to add a persistant storage location?
Many thanks!
Stan
