thanks for developing this great application!
We are almost there with our LDAP config, only some final hints needed. At least I hope so.
With the following config the admin users are able to login, also the admin button appears after login.
Only piece is missing to add the Nonadmin users. They’re in a different group: CN=spx_Nonadmins.
authentication: ldap
admin-groups: spx_Admins
ldap:
url: ldap://example.com:389/dc=example,dc=com
manager-dn: CN=spx_tech,OU=users,OU=accounts,OU=Department,DC=example,DC=com
manager-password: managerpass
group-search-base: OU=roles,OU=Department
group-search-filter: (CN=spx_Admins)
user-search-base:
user-search-filter: (sAMAccountName={0})
Can I add multiple groups to the group_search_filter? Or what would be the appropriate solution in this case?
Thanks in advance,
Imre
