After upgrade version from 2.3.1 to 2.6.0 my login by oidc stop work. I have few errors when i look at shinyproxy.log:
Using generated security password: 6b5a0b37-7d15-441b-82c2-7b521390f98c
2022-01-28 11:10:53.561 WARN 1617 — [main] org.thymeleaf.templatemode.TemplateMode : [THYMELEAF][main] Template Mode ‘HTML5’ is deprecated. Using Template Mode ‘HTML’ instead.
2022-01-28 11:10:53.566 INFO 1617 — [main] e.o.c.stat.StatCollectorFactory : Enabled. Sending usage statistics to jdbc:mysql://xx.xxx.xx.xxx:3306/admdev_test.
2022-01-28 11:10:53.875 INFO 1617 — [main] o.s.s.concurrent.ThreadPoolTaskExecutor : Initializing ExecutorService
2022-01-28 11:10:53.876 INFO 1617 — [main] o.s.s.concurrent.ThreadPoolTaskExecutor : Initializing ExecutorService ‘taskExecutor’
2022-01-28 11:10:54.198 INFO 1617 — [main] o.s.b.a.w.s.WelcomePageHandlerMapping : Adding welcome page template: index
2022-01-28 11:10:54.727 INFO 1617 — [main] o.s.l.c.support.AbstractContextSource : Property ‘userDn’ not set - anonymous context will be used for read-write operations
2022-01-28 11:10:54.983 INFO 1617 — [main] io.undertow : starting server: Undertow - 2.2.8.Final
2022-01-28 11:10:55.007 INFO 1617 — [main] org.xnio : XNIO version 3.8.4.Final
2022-01-28 11:10:55.033 INFO 1617 — [main] org.xnio.nio : XNIO NIO Implementation Version 3.8.4.Final
2022-01-28 11:10:55.145 INFO 1617 — [main] org.jboss.threads : JBoss Threads version 3.1.0.Final
2022-01-28 11:10:55.231 INFO 1617 — [main] o.s.b.w.e.undertow.UndertowWebServer : Undertow started on port(s) 8080 (http)
2022-01-28 11:10:55.378 INFO 1617 — [main] io.undertow.servlet : Initializing Spring embedded WebApplicationContext
2022-01-28 11:10:55.378 INFO 1617 — [main] w.s.c.ServletWebServerApplicationContext : Root WebApplicationContext: initialization completed in 141 ms
2022-01-28 11:10:55.397 INFO 1617 — [main] o.s.b.a.e.web.EndpointLinksResolver : Exposing 1 endpoint(s) beneath base path ‘/actuator’
2022-01-28 11:10:55.471 INFO 1617 — [main] io.undertow : starting server: Undertow - 2.2.8.Final
2022-01-28 11:10:55.517 INFO 1617 — [main] o.s.b.w.e.undertow.UndertowWebServer : Undertow started on port(s) 9090 (http)
2022-01-28 11:10:55.537 INFO 1617 — [main] e.o.c.util.StartupEventListener : Started ShinyProxy 2.6.0 (ContainerProxy 0.8.10)
2022-01-28 11:10:55.537 INFO 1617 — [main] e.o.c.service.AppRecoveryService : Recovery of running apps disabled
2022-01-28 11:11:19.442 INFO 1617 — [XNIO-1 task-1] io.undertow.servlet : Initializing Spring DispatcherServlet ‘dispatcherServlet’
2022-01-28 11:11:19.443 INFO 1617 — [XNIO-1 task-1] o.s.web.servlet.DispatcherServlet : Initializing Servlet ‘dispatcherServlet’
2022-01-28 11:11:19.451 INFO 1617 — [XNIO-1 task-1] o.s.web.servlet.DispatcherServlet : Completed initialization in 8 ms
2022-01-28 11:11:42.879 INFO 1617 — [XNIO-1 task-1] e.o.containerproxy.service.UserService : User logged in [user: test@test.com]
2022-01-28 11:11:42.880 INFO 1617 — [XNIO-1 task-1] com.zaxxer.hikari.HikariDataSource : HikariPool-1 - Starting…
2022-01-28 11:11:44.122 ERROR 1617 — [XNIO-1 task-1] com.zaxxer.hikari.pool.HikariPool : HikariPool-1 - Exception during pool initialization.java.sql.SQLException: Access denied for user ‘admdev’@‘Debian-95-stretch-64-LAMP’ (using password: YES)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129) ~[mysql-connector-java-8.0.25.jar!/:8.0.25]
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122) ~[mysql-connector-java-8.0.25.jar!/:8.0.25]
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:833) ~[mysql-connector-java-8.0.25.jar!/:8.0.25]
at com.mysql.cj.jdbc.ConnectionImpl.(ConnectionImpl.java:453) ~[mysql-connector-java-8.0.25.jar!/:8.0.25]
at com.mysql.cj.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:246) ~[mysql-connector-java-8.0.25.jar!/:8.0.25]
at com.mysql.cj.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:198) ~[mysql-connector-java-8.0.25.jar!/:8.0.25]
at com.zaxxer.hikari.util.DriverDataSource.getConnection(DriverDataSource.java:138) ~[HikariCP-3.4.5.jar!/:na]
at com.zaxxer.hikari.pool.PoolBase.newConnection(PoolBase.java:358) ~[HikariCP-3.4.5.jar!/:na]
at com.zaxxer.hikari.pool.PoolBase.newPoolEntry(PoolBase.java:206) ~[HikariCP-3.4.5.jar!/:na]
at com.zaxxer.hikari.pool.HikariPool.createPoolEntry(HikariPool.java:477) [HikariCP-3.4.5.jar!/:na]
at com.zaxxer.hikari.pool.HikariPool.checkFailFast(HikariPool.java:560) [HikariCP-3.4.5.jar!/:na]
at com.zaxxer.hikari.pool.HikariPool.(HikariPool.java:115) [HikariCP-3.4.5.jar!/:na]
at com.zaxxer.hikari.HikariDataSource.getConnection(HikariDataSource.java:112) [HikariCP-3.4.5.jar!/:na]
at eu.openanalytics.containerproxy.stat.impl.JDBCCollector.writeToDb(JDBCCollector.java:105) [containerproxy-0.8.10.jar!/:0.8.10]
at eu.openanalytics.containerproxy.stat.impl.AbstractDbCollector.onUserLoginEvent(AbstractDbCollector.java:38) [containerproxy-0.8.10.jar!/:0.8.10]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_242]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_242]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_242]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_242]
io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:104) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:160) [containerproxy-0.8.10.jar!/:0.8.10]
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:117) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.server.handlers.SameSiteCookieHandler.handleRequest(SameSiteCookieHandler.java:97) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.SendErrorPageHandler.handleRequest(SendErrorPageHandler.java:52) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99) [undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:387) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:841) [undertow-core-2.2.8.Final.jar!/:2.2.8.Final]
at org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35) [jboss-threads-3.1.0.Final.jar!/:3.1.0.Final]
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:2019) [jboss-threads-3.1.0.Final.jar!/:3.1.0.Final]
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1558) [jboss-threads-3.1.0.Final.jar!/:3.1.0.Final]
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1449) [jboss-threads-3.1.0.Final.jar!/:3.1.0.Final]
at org.xnio.XnioWorker$WorkerThreadFactory$1$1.run(XnioWorker.java:1280) [xnio-api-3.8.4.Final.jar!/:3.8.4.Final]
at java.lang.Thread.run(Thread.java:748) [na:1.8.0_242]2022-01-28 11:11:44.127 ERROR 1617 — [XNIO-1 task-1] io.undertow.request : UT005023: Exception handling request to /login/oauth2/code/shinyproxy
java.lang.reflect.UndeclaredThrowableException: Failed to invoke event listener method
HandlerMethod details:
Bean [eu.openanalytics.containerproxy.stat.impl.JDBCCollector]
Method [public void eu.openanalytics.containerproxy.stat.impl.AbstractDbCollector.onUserLoginEvent(eu.openanalytics.containerproxy.event.UserLoginEvent) throws java.io.IOException]
Resolved arguments:
[0] [type=eu.openanalytics.containerproxy.event.UserLoginEvent] [value=eu.openanalytics.containerproxy.event.UserLoginEvent[source=eu.openanalytics.containerproxy.service.UserService@751817d9]]at org.springframework.context.event.ApplicationListenerMethodAdapter.doInvoke(ApplicationListenerMethodAdapter.java:322) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.context.event.ApplicationListenerMethodAdapter.processEvent(ApplicationListenerMethodAdapter.java:190) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.context.event.ApplicationListenerMethodAdapter.onApplicationEvent(ApplicationListenerMethodAdapter.java:153) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.context.event.SimpleApplicationEventMulticaster.doInvokeListener(SimpleApplicationEventMulticaster.java:172) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:165) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:139) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:404) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:361) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at eu.openanalytics.containerproxy.service.UserService.onAuthenticationSuccessEvent(UserService.java:200) ~[containerproxy-0.8.10.jar!/:0.8.10]
at org.springframework.context.event.ApplicationListenerMethodAdapter.doInvoke(ApplicationListenerMethodAdapter.java:305) ~[spring-context-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.security.authentication.DefaultAuthenticationEventPublisher.publishAuthenticationSuccess(DefaultAuthenticationEventPublisher.java:103) ~[spring-security-core-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:243) ~[spring-security-core-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.oauth2.client.web.OAuth2LoginAuthenticationFilter.attemptAuthentication(OAuth2LoginAuthenticationFilter.java:185) ~[spring-security-oauth2-client-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:212) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.oauth2.client.web.OAuth2AuthorizationRequestRedirectFilter.doFilterInternal(OAuth2AuthorizationRequestRedirectFilter.java:160) ~[spring-security-oauth2-client-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119) ~[spring-web-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:117) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.header.HeaderWriterFilter.doHeadersAfter(HeaderWriterFilter.java:92) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:77) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178) ~[spring-security-web-5.3.9.RELEASE.jar!/:5.3.9.RELEASE]
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358) ~[spring-web-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271) ~[spring-web-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) ~[undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) ~[undertow-servlet-2.2.8.Final.jar!/:2.2.8.Final]
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:100) ~[spring-web-5.2.15.RELEASE.jar!/:5.2.15.RELEASE]
2022-01-28 11:11:45.000 INFO 1617 — [XNIO-1 task-1] e.o.containerproxy.service.UserService : User logged in [user: test@test.com]
2022-01-28 11:11:45.000 INFO 1617 — [XNIO-1 task-1] com.zaxxer.hikari.HikariDataSource : HikariPool-1 - Starting…
2022-01-28 11:11:46.003 ERROR 1617 — [XNIO-1 task-1] com.zaxxer.hikari.pool.HikariPool : HikariPool-1 - Exception during pool initialization.java.sql.SQLException: Access denied for user ‘admdev’@‘Debian-95-stretch-64-LAMP’ (using password: YES)
In browser i have redirection loop.
I am suprised there is information about successfull login and next there is few errors in my shinyproxy.log as you can see above:
2022-01-28 11:11:44.127 ERROR 1617 — [XNIO-1 task-1] io.undertow.request : UT005023: Exception handling request to /login/oauth2/code/shinyproxyjava.lang.reflect.UndeclaredThrowableException: Failed to invoke event listener method
information about mysql user (admdev) i have only in m server side. Settings for my mysql is ok so firstly i have info about successful login. I dont know why it show this error then. Also everything work ok when I downgrade to 2.3.1 i dont need to change anything in my server side.
Maybe anyone know what can i do to fix it?
