With the provided Grafana dashboard, we are able to see the “Start failure rate” but we don’t know which apps are affected unfortunately. Is it possible to get the information which apps do generate the “Start failure rate”? I don’t find anything in the exposed metrics though.
@tdekoninck is this something you would consider a feature request?
I think this can be useful, I created an internal ticket to implement this.
We will probably include this in the next release, but I cannot give an ETA yet.
@tdekoninck with a new release coming soon … did you had time to look into this?
Hi @prinn , we implemented this feature recently and it will be included in the next release.
In the meantime you could test this using the following snapshot: openanalytics/shinyproxy-snapshot:3.1.0-SNAPSHOT-20240102.145810
