I have created a shinyproxy app which can directly be accessed via
http://ip-address:8080/app_direct/fin/
Now I want to set up NGNIX proxy redirection from specified url to above specific address. The location block of Nginx.conf looks like below
location /CA/Fin/ {
rewrite ^/CA/Fin/(.*)$ /$1 break;
proxy_pass http://localhost:8080/app_direct/fin/;
proxy_redirect http://localhost:8080/app_direct/fin/ $scheme://$host/CA/Fin/;
proxy_http_version 1.1;
#proxy_set_header Connection $connection_upgrade;
proxy_read_timeout 2000d;
proxy_buffering off;
With above setting, when user put http://ip-address/CA/Fin/, the browser is actually redirecting to the shinyproxy’s app-listing page, whereas I want to get redirected directly to app.
Any pointer to setup right method to achieve the same will be highly appreciated.
