I manged to get shinyproxy working with Nginx in docker, but I still get the grey screen after exactly two minutes even though I set the proxy_*_timeout to 15 minutes. When I look at the network activity in chrome (F12) is shows that the websocket is pending for the two minutes until it grays out.
Any help will be much appreciated. I have both Nginx and Shinyproxy running in docker containers. I have the following Nginx config, where
shinyproxy is the docker host the shinyproxy container
worker_processes 4;
events { worker_connections 1024; }
http {
client_max_body_size 0;
sendfile on;
server_tokens off;
keepalive_timeout 900s;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
add_header X-Content-Type-Options nosniff;
add_header X-Frame-Options SAMEORIGIN;
add_header X-XSS-Protection "1; mode=block";
ssl_certificate /etc/nginx/cert.pem;
ssl_certificate_key /etc/nginx/private.key;
ssl_ciphers EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH;
ssl_prefer_server_ciphers on;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 10m;
ssl_stapling on;
ssl_stapling_verify on;
upstream shinyproxy_servers {
server shinyproxy:8080;
server {
listen 80;
listen [::]:80;
server_name example.com;
return 301 https://$host$request_uri;
server {
listen 443 ssl default_server;
listen [::]:443 ssl default_server;
server_name dcs-appsuite.com;
access_log /var/log/nginx/shinyproxy.access.log;
error_log /var/log/nginx/shinyproxy.error.log error;
location / {
proxy_pass http://shinyproxy_servers;
proxy_http_version 1.1;
proxy_connect_timeout 900s;
proxy_send_timeout 900s;
proxy_read_timeout 900s;
proxy_redirect off;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Protocol $scheme;
