I have a working app running on http, similar to the given example : https://github.com/openanalytics/shinyproxy-config-examples/tree/master/02-containerized-docker-engine
The only thing different is when launching the app i’m using another port 10029 to forward to 8080 to have access to the link (command). I do not have the access to the port 8080:
docker run -d -v /var/run/docker.sock:/var/run/docker.sock --net sp-example-net -p 10029:8080 shinyproxy-example
The link is now accessible http://hostname.com:10029
Now i’m trying to setup Ssl certificate so I can run my webapp on https. I’m using the config file from https://www.shinyproxy.io/security/#https-ssl-tls. I tried to replace the port 8080 with 10029 but no results (still showing link only on http)
I’ve already setup nginx and added certificates to corresponding path, using this tutorial https://www.youtube.com/watch?v=X3Pr5VATOyA
Here my /etc/nginx/conf.d/hostname.conf:
server {
listen 80;
server_name hostname.com;
rewrite ^(.*) https://$server_name$1 permanent;
}server {
listen 443 ssl;
access_log /var/log/nginx/shinyproxy.access.log;
error_log /var/log/nginx/shinyproxy.error.log error;#ssl on;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;ssl_certificate /etc/nginx/ssl/hostname.com.crt;
ssl_certificate_key /etc/nginx/ssl/hostname.com.key;location / {
proxy_pass http://127.0.0.1:10029;proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; proxy_read_timeout 600s; proxy_redirect off; proxy_set_header Host $http_host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Proto $scheme; }
Do you know what could be wrong with my config. ?
Any help would be appreciated
Thank you
