We are running shinyproxy webpps on AWS EC2 instance .
We are able to run shinyprioy version 2.3.0 , 2.4.0 while using oauth2
When we change shinyproxy version from 2.3.0 -> 2.5.0 on AWS EC2 instance after running commands
sudo wget downloadproxy
unlink shinyproxy.jar
ln -s shinyproxy-2.5.0.jar shinyproxy.jar
sudo service shinyproxy restart
we get the following error
Field webSecurityConfigurerAdapter in eu.openanalytics.containerproxy.auth.impl.KeycloakAuthenticationBackend required a single bean, but 2 were found:
May 16 04:50:46 ip-172-31-73-41 java[28433]: - webSecurityConfig: defined in URL [jar:file:/opt/shinyproxy/shinyproxy-2.5.0.jar!/BOOT-INF/lib/containerproxy-0.8.8.j
May 16 04:50:46 ip-172-31-73-41 java[28433]: - org.springframework.security.oauth2.config.annotation.web.configuration.ResourceServerConfiguration: defined in null
The same application.yaml file works for version shinyproxy version 2.3.0 and 2.4.0 but not for 2.5.0 and above. Could someone please help us ?
Here is our application.yaml file.
useForwardHeaders: true
title: “shreyashtoday”
logo-url: someurl
heartbeat-timeout: 60000
admin-groups: some
oauth2:
resource-id: someid
jwks-url: someurl
- name: aa
password: aaa
groups: client
cert-path: /home/none
url: http://localhost:2375
port-range-start: 20000
- id: default
display-name: shreyashtestingtoday
description: “shreyashtesting for inactive users”
port: 3838
container-cmd: ["R", "-e", "shiny::runApp('/root/content/app.R', port = 3838, host='0.0.0.0')"]
groups: some ,something
