I would like to integrate shinyproxy using ADFS as the identity provider. I asked our tech guys to setup the config, but I get an error saying java.lang.IllegalArgumentException: Missing attribute 'email' in attributes. I did check with the tech guys that they enables the email scope, but the error still remains.
Any help would be appreciated.
The url that gets generated is as follows:
https://<URL>/adfs/oauth2/authorize?response_type=code&client_id=<CLIENT_ID>&scope=openid%20email&state=IYYQu2Ej0UMTBXFRYiNSg2iZRh03Rckj0fX-bCl8wlI%3D&redirect_uri=http://<URI>/login/oauth2/code/shinyproxy
and the config:
logo-url: http://www.openanalytics.eu/sites/www.openanalytics.eu/themes/oa/logo.png
heartbeat-timeout: 60000
authentication: openid
openid:
auth-url: https://<URL>/adfs/oauth2/authorize
token-url: https://<URL>/adfs/oauth2/token
jwks-url: https://<URL>/adfs/discovery/keys
client-id: <CLIENT_ID>
client-secret: <CLIENT_SECRET>
# Docker configuration
url: http://localhost:2375
port-range-start: 20000
support:
container-log-path: ./container-logs
- id: 01_hello
- id: 06_tabsets
