I’m using the version 2.6.1 in an Ubuntu 20.04 server with NGINX reverse proxy and the openid authentication. Just after enter my credentials, I receive the following error message:
GET https:///login/oauth2/code/shinyproxy?error_description=Error in SAML response processing: RedirectUri is not registered with the client &state=EAd0BE5PZWg1LIt6WDOk8X6vYFziRGdnMcBLhsOLxzU=&error=server_error
I have already applied:
- forward-headers-strategy: native
- secure-cookies: True
- same-site-cookie: None
My NGINX configuration is according to the one suggested in shinyproxy.io docs:
server {
listen 80;
server_name ${shiny_server_name};
rewrite ^(.*) https://$server_name$1 permanent;
server {
listen 443;
access_log /var/log/nginx/shinyproxy.access.log;
error_log /var/log/nginx/shinyproxy.error.log error;
ssl on;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_certificate /etc/ssl/certs/shinyproxy_initial.crt;
ssl_certificate_key /etc/ssl/private/shinyproxy_initial.key;
location / {
proxy_pass http://127.0.0.1:8080/;
proxy_http_version 1.1;
proxy_read_timeout 600s;
proxy_redirect off;
proxy_set_header Host $http_host;
Could you help me to find what is missing?
Thanks
