Phaedra 1.0.6 installation on Linux not working
Hi OA
Has anyone had Phaedra 1.0.6 running on Ubunto?
When open Phaedra after installing version 1.0.6 on Ubuntu 18.10. I get the following error:
(anaconda3)sune@sune-X380:/opt/phaedra$ ./phaedra
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x0000000000038870, pid=1214, tid=0x00007fb0dc6ee700
JRE version: OpenJDK Runtime Environment (8.0_92-b15) (build 1.8.0_92-b15)
Java VM: OpenJDK 64-Bit Server VM (25.92-b15 mixed mode linux-amd64 compressed oops)
Problematic frame:
C 0x0000000000038870
Failed to write core dump. Core dumps have been disabled. To enable core dumping, try “ulimit -c unlimited” before starting Java again
An error report file with more information is saved as:
/tmp/hs_err_pid1214.log
If you would like to submit a bug report, please visit:
http://www.azulsystems.com/support/
Content of error log:
-------------- T H R E A D ---------------
Current thread (0x00007fce7800a000): JavaThread “main” [_thread_in_native, id=17697, stack(0x00007fce7cbd6000,0x00007fce7ccd6000)]
siginfo: si_signo: 11 (SIGSEGV), si_code: 1 (SEGV_MAPERR), si_addr: 0x0000000000038870
Registers:
RAX=0x0000000000000000, RBX=0x00007fce402b1850, RCX=0x00007fce7835b780, RDX=0x00007fce7835b780
RSP=0x00007fce7ccd3f58, RBP=0x0000000000000022, RSI=0x00007ffc148564f8, RDI=0x0000000000000022
R8 =0x00007fce782d8790, R9 =0x000000000000002f, R10=0x00007fce78000080, R11=0x00007fce78000080
R12=0x00007ffc148564f8, R13=0x00007fce7835b780, R14=0x00007fce402b1858, R15=0x0000000000000000
RIP=0x0000000000038870, EFLAGS=0x0000000000010202, CSGSFS=0x002b000000000033, ERR=0x0000000000000014
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007fce7ccd3f58)
0x00007fce7ccd3f58: 00007fce7e1bc95a 0000000000000010
0x00007fce7ccd3f68: 0000000000000022 00007ffc148564f8
0x00007fce7ccd3f78: 00007fce7835b780 00007fce782ffc30
0x00007fce7ccd3f88: 00007fce7e1bca59 000000cc000000cb
0x00007fce7ccd3f98: 0000000000000000 00007fce7ccd4060
0x00007fce7ccd3fa8: 00007fce782ffc30 0000000000000013
0x00007fce7ccd3fb8: 0000000000000013 00007fce7ccd41c0
0x00007fce7ccd3fc8: 00007fce7e1c0cbc 00007fce782ffc30
0x00007fce7ccd3fd8: 00007fce7e1c0a6a 00007fce7ccd4540
0x00007fce7ccd3fe8: 00007fce7ccd41b0 00007fce7ccd4190
0x00007fce7ccd3ff8: 00007fce782e1780 0000000000000000
0x00007fce7ccd4008: 00007fce7ccd41c0 00007fce7ccd3fe0
0x00007fce7ccd4018: 00007fce7e1d8160 8000000100000001
0x00007fce7ccd4028: 00007fce00000001 0000000000000000
0x00007fce7ccd4038: 0000000000000000 00007fce40451476
0x00007fce7ccd4048: 00007fce404501a2 0000000000000022
0x00007fce7ccd4058: 00007fce7e1d7060 0000000080000001
0x00007fce7ccd4068: 00007fce7dec55cf 00007fce7ccd4290
0x00007fce7ccd4078: 00007fce7ccd41a0 00007fce7e1c08a0
0x00007fce7ccd4088: 00007fce7ccd41c0 00007fce782e1780
0x00007fce7ccd4098: 0000000000000000 00007fce7ccd41a0
0x00007fce7ccd40a8: 00007fce7ccd409c 0000000000000000
0x00007fce7ccd40b8: c3346b4bd4812af0 00007fce40451476
0x00007fce7ccd40c8: 00007fce404501a2 0000000000000022
0x00007fce7ccd40d8: 00007fce7e1d7060 3ca992d154632af0
0x00007fce7ccd40e8: 3ca990937ff92af0 6168732f00000000
0x00007fce7ccd40f8: 6c61636f6c2f6572 415353454d5f434c
0x00007fce7ccd4108: 6362696c2f534547 0000000000000000
0x00007fce7ccd4118: ff00ffffffffffff 2525252525252525
0x00007fce7ccd4128: 6fdd1c976465f600 ff0000ff00000000
0x00007fce7ccd4138: 00007fce7830bca0 00007fce782e41b0
0x00007fce7ccd4148: 00007fce78300cf0 0000000000000012
Instructions: (pc=0x0000000000038870)
0x0000000000038850:
[error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xb]
Register to memory mapping:
RAX=0x0000000000000000 is an unknown value
RBX=0x00007fce402b1850: <offset 0x19b850> in /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0 at 0x00007fce40116000
RCX=0x00007fce7835b780 is an unknown value
RDX=0x00007fce7835b780 is an unknown value
RSP=0x00007fce7ccd3f58 is pointing into the stack for thread: 0x00007fce7800a000
RBP=0x0000000000000022 is an unknown value
RSI=0x00007ffc148564f8 is an unknown value
RDI=0x0000000000000022 is an unknown value
R8 =0x00007fce782d8790 is an unknown value
R9 =0x000000000000002f is an unknown value
R10=0x00007fce78000080 is an unknown value
R11=0x00007fce78000080 is an unknown value
R12=0x00007ffc148564f8 is an unknown value
R13=0x00007fce7835b780 is an unknown value
R14=0x00007fce402b1858: <offset 0x19b858> in /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0 at 0x00007fce40116000
R15=0x0000000000000000 is an unknown value
Stack: [0x00007fce7cbd6000,0x00007fce7ccd6000], sp=0x00007fce7ccd3f58, free space=1015k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.equinox.launcher.JNIBridge._show_splash(Ljava/lang/String;)V+0
j org.eclipse.equinox.launcher.JNIBridge.showSplash(Ljava/lang/String;)Z+2
j org.eclipse.equinox.launcher.Main.handleSplash([Ljava/net/URL;)V+158
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+150
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V+10
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00007fce78218800 JavaThread “Service Thread” daemon [_thread_blocked, id=17714, stack(0x00007fce40755000,0x00007fce40856000)]
0x00007fce7820d000 JavaThread “C1 CompilerThread3” daemon [_thread_blocked, id=17713, stack(0x00007fce40857000,0x00007fce40957000)]
0x00007fce7820b000 JavaThread “C2 CompilerThread2” daemon [_thread_blocked, id=17712, stack(0x00007fce40958000,0x00007fce40a58000)]
0x00007fce78209800 JavaThread “C2 CompilerThread1” daemon [_thread_blocked, id=17711, stack(0x00007fce40a59000,0x00007fce40b59000)]
0x00007fce78206800 JavaThread “C2 CompilerThread0” daemon [_thread_blocked, id=17710, stack(0x00007fce40b5a000,0x00007fce40c5a000)]
0x00007fce78205000 JavaThread “Signal Dispatcher” daemon [_thread_blocked, id=17709, stack(0x00007fce40c5a000,0x00007fce40d5b000)]
0x00007fce781d2000 JavaThread “Finalizer” daemon [_thread_blocked, id=17708, stack(0x00007fce41595000,0x00007fce41696000)]
0x00007fce781cd800 JavaThread “Reference Handler” daemon [_thread_blocked, id=17707, stack(0x00007fce41696000,0x00007fce41797000)]
=>0x00007fce7800a000 JavaThread “main” [_thread_in_native, id=17697, stack(0x00007fce7cbd6000,0x00007fce7ccd6000)]
Other Threads:
0x00007fce781c6000 VMThread [stack: 0x00007fce41798000,0x00007fce41898000] [id=17706]
0x00007fce7821b000 WatcherThread [stack: 0x00007fce40655000,0x00007fce40755000] [id=17715]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
PSYoungGen total 74240K, used 3841K [0x00000000d5580000, 0x00000000da800000, 0x0000000100000000)
eden space 64000K, 6% used [0x00000000d5580000,0x00000000d5940430,0x00000000d9400000)
from space 10240K, 0% used [0x00000000d9e00000,0x00000000d9e00000,0x00000000da800000)
to space 10240K, 0% used [0x00000000d9400000,0x00000000d9400000,0x00000000d9e00000)
ParOldGen total 169472K, used 0K [0x0000000080000000, 0x000000008a580000, 0x00000000d5580000)
object space 169472K, 0% used [0x0000000080000000,0x0000000080000000,0x000000008a580000)
Metaspace used 4447K, capacity 4690K, committed 4864K, reserved 1056768K
class space used 456K, capacity 462K, committed 512K, reserved 1048576K
Card table byte_map: [0x00007fce68bff000,0x00007fce69000000] byte_map_base: 0x00007fce687ff000
Marking Bits: (ParMarkBitMap*) 0x00007fce7dd36840
Begin Bits: [0x00007fce48000000, 0x00007fce4a000000)
End Bits: [0x00007fce4a000000, 0x00007fce4c000000)
Polling page: 0x00007fce7e1ab000
CodeCache: size=245760Kb used=1431Kb max_used=1443Kb free=244328Kb
bounds [0x00007fce69000000, 0x00007fce69270000, 0x00007fce78000000]
total_blobs=440 nmethods=173 adapters=182
compilation: enabled
Compilation events (10 events):
Event: 0.112 Thread 0x00007fce7820d000 169 3 org.eclipse.equinox.launcher.Main::isMatchingCandidate (155 bytes)
Event: 0.113 Thread 0x00007fce7820d000 nmethod 169 0x00007fce69161410 code [0x00007fce69161720, 0x00007fce69163338]
Event: 0.113 Thread 0x00007fce7820d000 171 3 java.util.zip.ZStreamRef::address (5 bytes)
Event: 0.113 Thread 0x00007fce7820d000 nmethod 171 0x00007fce69166f10 code [0x00007fce69167060, 0x00007fce691671b0]
Event: 0.113 Thread 0x00007fce7820b000 nmethod 162 0x00007fce69167210 code [0x00007fce69167360, 0x00007fce691675b8]
Event: 0.115 Thread 0x00007fce7820d000 172 3 java.io.UnixFileSystem::normalize (75 bytes)
Event: 0.116 Thread 0x00007fce7820d000 nmethod 172 0x00007fce691663d0 code [0x00007fce691665a0, 0x00007fce69166be8]
Event: 0.116 Thread 0x00007fce7820d000 173 3 java.util.Vector::ensureCapacityHelper (16 bytes)
Event: 0.116 Thread 0x00007fce7820d000 nmethod 173 0x00007fce69165fd0 code [0x00007fce69166140, 0x00007fce69166308]
Event: 0.116 Thread 0x00007fce78206800 nmethod 161 0x00007fce691640d0 code [0x00007fce69164240, 0x00007fce69164928]
GC Heap History (0 events):
No events
Deoptimization events (1 events):
Event: 0.092 Thread 0x00007fce7800a000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00007fce6914cadc method=java.lang.String.
hashCode()I @ 14
Internal exceptions (3 events):
Event: 0.016 Thread 0x00007fce7800a000 Exception <a ‘java/lang/NoSuchMethodError’: Method sun.misc.Unsafe.defineClass(Ljava/lang/String;[B
II)Ljava/lang/Class; name or signature does not match> (0x00000000d5587cc0) thrown at [/export/home/tester/jenkins/workspace/zulu8-silver-
build-rhel64/zulu-
Event: 0.016 Thread 0x00007fce7800a000 Exception <a ‘java/lang/NoSuchMethodError’: Method sun.misc.Unsafe.prefetchRead(Ljava/lang/Object;J
)V name or signature does not match> (0x00000000d5587fa8) thrown at [/export/home/tester/jenkins/workspace/zulu8-silver-build-rhel64/zulu-
src/hotspot/src/sh
Event: 0.115 Thread 0x00007fce7800a000 Exception <a ‘java/lang/UnsatisfiedLinkError’: org.eclipse.equinox.launcher.JNIBridge._set_launcher
_info(Ljava/lang/String;Ljava/lang/String;)V> (0x00000000d58fbef8) thrown at [/export/home/tester/jenkins/workspace/zulu8-silver-build-rhe
l64/zulu-src/hotsp
Events (10 events):
Event: 0.109 loading class java/lang/ApplicationShutdownHooks$1
Event: 0.109 loading class java/lang/ApplicationShutdownHooks$1 done
Event: 0.109 loading class java/lang/Shutdown
Event: 0.109 loading class java/lang/Shutdown done
Event: 0.109 loading class java/lang/Shutdown$Lock
Event: 0.109 loading class java/lang/Shutdown$Lock done
Event: 0.109 loading class java/util/IdentityHashMap
Event: 0.109 loading class java/util/IdentityHashMap done
Event: 0.115 loading class java/io/FileOutputStream$1
Event: 0.115 loading class java/io/FileOutputStream$1 done
Dynamic libraries:
00400000-00401000 r-xp 00000000 fd:01 4989401 /opt/phaedra/jre/bin/java
00600000-00601000 rw-p 00000000 fd:01 4989401 /opt/phaedra/jre/bin/java
00f2a000-00f4b000 rw-p 00000000 00:00 0 [heap]
80000000-8a580000 rw-p 00000000 00:00 0
8a580000-d5580000 —p 00000000 00:00 0
d5580000-da800000 rw-p 00000000 00:00 0
da800000-100000000 —p 00000000 00:00 0
100000000-100080000 rw-p 00000000 00:00 0
100080000-140000000 —p 00000000 00:00 0
7fce14000000-7fce14021000 rw-p 00000000 00:00 0
7fce14021000-7fce18000000 —p 00000000 00:00 0
7fce19ca9000-7fce19cb3000 r–p 00000000 fd:01 6165313 /lib/x86_64-linux-gnu/libblkid.so.1.1.0
7fce19cb3000-7fce19ce4000 r-xp 0000a000 fd:01 6165313 /lib/x86_64-linux-gnu/libblkid.so.1.1.0
7fce19ce4000-7fce19cf4000 r–p 0003b000 fd:01 6165313 /lib/x86_64-linux-gnu/libblkid.so.1.1.0
7fce19cf4000-7fce19cf8000 r–p 0004a000 fd:01 6165313 /lib/x86_64-linux-gnu/libblkid.so.1.1.0
7fce19cf8000-7fce19cf9000 rw-p 0004e000 fd:01 6165313 /lib/x86_64-linux-gnu/libblkid.so.1.1.0
7fce19cf9000-7fce19cfa000 rw-p 00000000 00:00 0
7fce1a4d5000-7fce1a4d7000 r–p 00000000 fd:01 6165486 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7fce1a4d7000-7fce1a4db000 r-xp 00002000 fd:01 6165486 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7fce1a4db000-7fce1a4dc000 r–p 00006000 fd:01 6165486 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7fce1a4dc000-7fce1a4dd000 r–p 00006000 fd:01 6165486 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7fce1a4dd000-7fce1a4de000 rw-p 00007000 fd:01 6165486 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7fce1a51b000-7fce1a51d000 r–p 00000000 fd:01 6165541 /lib/x86_64-linux-gnu/libpcre.so.3.13.3
7fce1a51d000-7fce1a56f000 r-xp 00002000 fd:01 6165541 /lib/x86_64-linux-gnu/libpcre.so.3.13.3
7fce1a56f000-7fce1a58d000 r–p 00054000 fd:01 6165541 /lib/x86_64-linux-gnu/libpcre.so.3.13.3
7fce1a58d000-7fce1a58e000 r–p 00071000 fd:01 6165541 /lib/x86_64-linux-gnu/libpcre.so.3.13.3
7fce1a58e000-7fce1a58f000 rw-p 00072000 fd:01 6165541 /lib/x86_64-linux-gnu/libpcre.so.3.13.3
7fce1a58f000-7fce1a591000 r–p 00000000 fd:01 13631664 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7fce1a591000-7fce1a596000 r-xp 00002000 fd:01 13631664 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7fce1a596000-7fce1a597000 r–p 00007000 fd:01 13631664 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7fce1a597000-7fce1a598000 r–p 00007000 fd:01 13631664 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7fce1a598000-7fce1a599000 rw-p 00008000 fd:01 13631664 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7fce1a599000-7fce1a5a4000 r–p 00000000 fd:01 6165388 /lib/x86_64-linux-gnu/libmount.so.1.1.0
7fce1a5a4000-7fce1a5dc000 r-xp 0000b000 fd:01 6165388 /lib/x86_64-linux-gnu/libmount.so.1.1.0
7fce1a5dc000-7fce1a5ee000 r–p 00043000 fd:01 6165388 /lib/x86_64-linux-gnu/libmount.so.1.1.0
7fce1a5ee000-7fce1a5f0000 r–p 00054000 fd:01 6165388 /lib/x86_64-linux-gnu/libmount.so.1.1.0
7fce1a5f0000-7fce1a5f1000 rw-p 00056000 fd:01 6165388 /lib/x86_64-linux-gnu/libmount.so.1.1.0
7fce1a5f1000-7fce1a5f2000 rw-p 00000000 00:00 0
7fce1a5f2000-7fce1a5f6000 r–p 00000000 fd:01 6184795 /lib/x86_64-linux-gnu/libresolv-2.29.so
7fce1a5f6000-7fce1a605000 r-xp 00004000 fd:01 6184795 /lib/x86_64-linux-gnu/libresolv-2.29.so
7fce1a605000-7fce1a608000 r–p 00013000 fd:01 6184795 /lib/x86_64-linux-gnu/libresolv-2.29.so
7fce1a608000-7fce1a609000 —p 00016000 fd:01 6184795 /lib/x86_64-linux-gnu/libresolv-2.29.so
7fce1a609000-7fce1a60a000 r–p 00016000 fd:01 6184795 /lib/x86_64-linux-gnu/libresolv-2.29.so
7fce1a60a000-7fce1a60b000 rw-p 00017000 fd:01 6184795 /lib/x86_64-linux-gnu/libresolv-2.29.so
7fce1a60b000-7fce1a60d000 rw-p 00000000 00:00 0
7fce1a60d000-7fce1a632000 r-xp 00000000 fd:01 6165461 /lib/x86_64-linux-gnu/libselinux.so.1
7fce1a632000-7fce1a831000 —p 00025000 fd:01 6165461 /lib/x86_64-linux-gnu/libselinux.so.1
7fce1a831000-7fce1a832000 r–p 00024000 fd:01 6165461 /lib/x86_64-linux-gnu/libselinux.so.1
7fce1a832000-7fce1a833000 rw-p 00025000 fd:01 6165461 /lib/x86_64-linux-gnu/libselinux.so.1
7fce1a833000-7fce1a835000 rw-p 00000000 00:00 0
7fce1a835000-7fce1a851000 r-xp 00000000 fd:01 6165490 /lib/x86_64-linux-gnu/libz.so.1.2.11
7fce1a851000-7fce1aa50000 —p 0001c000 fd:01 6165490 /lib/x86_64-linux-gnu/libz.so.1.2.11
7fce1aa50000-7fce1aa51000 r–p 0001b000 fd:01 6165490 /lib/x86_64-linux-gnu/libz.so.1.2.11
7fce1aa51000-7fce1aa52000 rw-p 0001c000 fd:01 6165490 /lib/x86_64-linux-gnu/libz.so.1.2.11
7fce1aa52000-7fce1aa53000 r–p 00000000 fd:01 13631858 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.5800.1
7fce1aa53000-7fce1aa55000 r-xp 00001000 fd:01 13631858 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.5800.1
7fce1aa55000-7fce1aa56000 r–p 00003000 fd:01 13631858 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.5800.1
7fce1aa56000-7fce1aa57000 r–p 00003000 fd:01 13631858 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.5800.1
7fce1aa57000-7fce1aa58000 rw-p 00004000 fd:01 13631858 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.5800.1
7fce1bee3000-7fce1befe000 r–p 00000000 fd:01 13631833 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.5800.1
7fce1befe000-7fce1bf7b000 r-xp 0001b000 fd:01 13631833 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.5800.1
7fce1bf7b000-7fce1bffd000 r–p 00098000 fd:01 13631833 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.5800.1
7fce1bffd000-7fce1bffe000 r–p 00119000 fd:01 13631833 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.5800.1
7fce1bffe000-7fce1bfff000 rw-p 0011a000 fd:01 13631833 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.5800.1
7fce1bfff000-7fce1c000000 rw-p 00000000 00:00 0
7fce1c000000-7fce1c14e000 rw-p 00000000 00:00 0
7fce1c14e000-7fce20000000 —p 00000000 00:00 0
7fce20000000-7fce20021000 rw-p 00000000 00:00 0
7fce20021000-7fce24000000 —p 00000000 00:00 0
7fce24000000-7fce2403f000 rw-p 00000000 00:00 0
7fce2403f000-7fce28000000 —p 00000000 00:00 0
7fce28000000-7fce2805d000 rw-p 00000000 00:00 0
7fce2805d000-7fce2c000000 —p 00000000 00:00 0
7fce2c000000-7fce2c021000 rw-p 00000000 00:00 0
7fce2c021000-7fce30000000 —p 00000000 00:00 0
7fce30000000-7fce300e8000 rw-p 00000000 00:00 0
7fce300e8000-7fce34000000 —p 00000000 00:00 0
7fce34000000-7fce34021000 rw-p 00000000 00:00 0
7fce34021000-7fce38000000 —p 00000000 00:00 0
7fce38000000-7fce38021000 rw-p 00000000 00:00 0
7fce38021000-7fce3c000000 —p 00000000 00:00 0
7fce3c000000-7fce3c021000 rw-p 00000000 00:00 0
7fce3c021000-7fce40000000 —p 00000000 00:00 0
7fce400c2000-7fce400cd000 r–p 00000000 fd:01 13631859 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.5800.1
7fce400cd000-7fce400fe000 r-xp 0000b000 fd:01 13631859 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.5800.1
7fce400fe000-7fce40114000 r–p 0003c000 fd:01 13631859 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.5800.1
7fce40114000-7fce40115000 r–p 00051000 fd:01 13631859 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.5800.1
7fce40115000-7fce40116000 rw-p 00052000 fd:01 13631859 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.5800.1
7fce40116000-7fce4014b000 r–p 00000000 fd:01 13631825 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.5800.1
7fce4014b000-7fce40234000 r-xp 00035000 fd:01 13631825 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.5800.1
7fce40234000-7fce402b0000 r–p 0011e000 fd:01 13631825 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.5800.1
7fce402b0000-7fce402b1000 —p 0019a000 fd:01 13631825 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.5800.1
7fce402b1000-7fce402b9000 rw-p 0019a000 fd:01 13631825 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.5800.1
7fce402b9000-7fce402bb000 rw-p 00000000 00:00 0
7fce4041c000-7fce40422000 r–p 00000000 fd:01 13639338 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3800.0
7fce40422000-7fce40437000 r-xp 00006000 fd:01 13639338 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3800.0
7fce40437000-7fce4043f000 r–p 0001b000 fd:01 13639338 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3800.0
7fce4043f000-7fce40440000 —p 00023000 fd:01 13639338 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3800.0
7fce40440000-7fce40441000 r–p 00023000 fd:01 13639338 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3800.0
7fce40441000-7fce40442000 rw-p 00024000 fd:01 13639338 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3800.0
7fce40442000-7fce40453000 r-xp 00000000 fd:01 4989653 /opt/phaedra/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_6
4_1.1.400.v20160518-1444/eclipse_1617.so
7fce40453000-7fce40652000 —p 00011000 fd:01 4989653 /opt/phaedra/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_6
7fce40652000-7fce40654000 rw-p 00010000 fd:01 4989653 /opt/phaedra/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_6
7fce40654000-7fce40655000 —p 00000000 00:00 0
7fce40655000-7fce40755000 rw-p 00000000 00:00 0
7fce40755000-7fce40758000 —p 00000000 00:00 0
7fce40758000-7fce40856000 rw-p 00000000 00:00 0
7fce40856000-7fce40857000 —p 00000000 00:00 0
7fce40857000-7fce4085a000 —p 00000000 00:00 0
7fce4085a000-7fce40957000 rw-p 00000000 00:00 0
7fce40957000-7fce40958000 —p 00000000 00:00 0
7fce40958000-7fce4095b000 —p 00000000 00:00 0
7fce4095b000-7fce40a58000 rw-p 00000000 00:00 0
7fce40a58000-7fce40a59000 —p 00000000 00:00 0
7fce40a59000-7fce40a5c000 —p 00000000 00:00 0
7fce40a5c000-7fce40b59000 rw-p 00000000 00:00 0
7fce40b59000-7fce40b5a000 —p 00000000 00:00 0
7fce40b5a000-7fce40b5d000 —p 00000000 00:00 0
7fce40b5d000-7fce40c5a000 rw-p 00000000 00:00 0
7fce40c5a000-7fce40c5d000 —p 00000000 00:00 0
7fce40c5d000-7fce40d5b000 rw-p 00000000 00:00 0
7fce40d5b000-7fce41595000 r–p 00000000 fd:01 13649381 /usr/lib/locale/locale-archive
7fce41595000-7fce41598000 —p 00000000 00:00 0
7fce41598000-7fce41696000 rw-p 00000000 00:00 0
7fce41696000-7fce41699000 —p 00000000 00:00 0
7fce41699000-7fce41797000 rw-p 00000000 00:00 0
7fce41797000-7fce41798000 —p 00000000 00:00 0
7fce41798000-7fce43840000 rw-p 00000000 00:00 0
7fce43840000-7fce43c00000 —p 00000000 00:00 0
7fce43c00000-7fce44000000 rw-p 00000000 00:00 0
7fce44000000-7fce44021000 rw-p 00000000 00:00 0
7fce44021000-7fce48000000 —p 00000000 00:00 0
7fce48000000-7fce4c000000 rw-p 00000000 00:00 0
7fce4c000000-7fce4c021000 rw-p 00000000 00:00 0
7fce4c021000-7fce50000000 —p 00000000 00:00 0
7fce50000000-7fce50021000 rw-p 00000000 00:00 0
7fce50021000-7fce54000000 —p 00000000 00:00 0
7fce54000000-7fce54021000 rw-p 00000000 00:00 0
7fce54021000-7fce58000000 —p 00000000 00:00 0
7fce58000000-7fce58021000 rw-p 00000000 00:00 0
7fce58021000-7fce5c000000 —p 00000000 00:00 0
7fce5c000000-7fce5c021000 rw-p 00000000 00:00 0
7fce5c021000-7fce60000000 —p 00000000 00:00 0
7fce60000000-7fce60021000 rw-p 00000000 00:00 0
7fce60021000-7fce64000000 —p 00000000 00:00 0
7fce64000000-7fce64021000 rw-p 00000000 00:00 0
7fce64021000-7fce68000000 —p 00000000 00:00 0
7fce6800a000-7fce681d7000 r–s 03bec000 fd:01 4989517 /opt/phaedra/jre/lib/rt.jar
7fce681d7000-7fce6824d000 rw-p 00000000 00:00 0
7fce6824d000-7fce6824e000 —p 00000000 00:00 0
7fce6824e000-7fce6834e000 rw-p 00000000 00:00 0
7fce6834e000-7fce6834f000 —p 00000000 00:00 0
7fce6834f000-7fce6844f000 rw-p 00000000 00:00 0
7fce6844f000-7fce68450000 —p 00000000 00:00 0
7fce68450000-7fce68550000 rw-p 00000000 00:00 0
7fce68550000-7fce68551000 —p 00000000 00:00 0
7fce68551000-7fce68651000 rw-p 00000000 00:00 0
7fce68651000-7fce68652000 —p 00000000 00:00 0
7fce68652000-7fce68752000 rw-p 00000000 00:00 0
7fce68752000-7fce68753000 —p 00000000 00:00 0
7fce68753000-7fce68853000 rw-p 00000000 00:00 0
7fce68853000-7fce68854000 —p 00000000 00:00 0
7fce68854000-7fce689a7000 rw-p 00000000 00:00 0
7fce689a7000-7fce68bff000 —p 00000000 00:00 0
7fce68bff000-7fce68c52000 rw-p 00000000 00:00 0
7fce68c52000-7fce68ea9000 —p 00000000 00:00 0
7fce68ea9000-7fce68ed3000 rw-p 00000000 00:00 0
7fce68ed3000-7fce68fff000 —p 00000000 00:00 0
7fce68fff000-7fce69000000 rw-p 00000000 00:00 0
7fce69000000-7fce69270000 rwxp 00000000 00:00 0
7fce69270000-7fce78000000 —p 00000000 00:00 0
7fce78000000-7fce78374000 rw-p 00000000 00:00 0
7fce78374000-7fce7c000000 —p 00000000 00:00 0
7fce7c007000-7fce7c022000 r–p 00000000 fd:01 2127654 /etc/ld.so.cache
7fce7c022000-7fce7c023000 r–s 00082000 fd:01 4989775 /opt/phaedra/plugins/eu.openanalytics.phaedra.product_1.0.6.20190
4090639.jar
7fce7c023000-7fce7c026000 r–s 00039000 fd:01 4990326 /opt/phaedra/plugins/org.eclipse.osgi.compatibility.state_1.0.200
.v20160504-1419.jar
7fce7c026000-7fce7c029000 r–s 00015000 fd:01 4989437 /opt/phaedra/jre/lib/jce.jar
7fce7c029000-7fce7c0ac000 rw-p 00000000 00:00 0
7fce7c0ac000-7fce7c0ad000 —p 00000000 00:00 0
7fce7c0ad000-7fce7c1b7000 rw-p 00000000 00:00 0
7fce7c1b7000-7fce7c56d000 —p 00000000 00:00 0
7fce7c56d000-7fce7c587000 r-xp 00000000 fd:01 4989471 /opt/phaedra/jre/lib/amd64/libzip.so
7fce7c587000-7fce7c786000 —p 0001a000 fd:01 4989471 /opt/phaedra/jre/lib/amd64/libzip.so
7fce7c786000-7fce7c787000 rw-p 00019000 fd:01 4989471 /opt/phaedra/jre/lib/amd64/libzip.so
7fce7c787000-7fce7c78f000 rw-s 00000000 fd:01 12976216 /tmp/hsperfdata_root/17696
7fce7c78f000-7fce7c7b9000 r-xp 00000000 fd:01 4989488 /opt/phaedra/jre/lib/amd64/libjava.so
7fce7c7b9000-7fce7c9b9000 —p 0002a000 fd:01 4989488 /opt/phaedra/jre/lib/amd64/libjava.so
7fce7c9b9000-7fce7c9bb000 rw-p 0002a000 fd:01 4989488 /opt/phaedra/jre/lib/amd64/libjava.so
7fce7c9bb000-7fce7c9c8000 r-xp 00000000 fd:01 4989470 /opt/phaedra/jre/lib/amd64/libverify.so
7fce7c9c8000-7fce7cbc8000 —p 0000d000 fd:01 4989470 /opt/phaedra/jre/lib/amd64/libverify.so
7fce7cbc8000-7fce7cbca000 rw-p 0000d000 fd:01 4989470 /opt/phaedra/jre/lib/amd64/libverify.so
7fce7cbca000-7fce7cbcd000 r–p 00000000 fd:01 6184796 /lib/x86_64-linux-gnu/librt-2.29.so
7fce7cbcd000-7fce7cbd1000 r-xp 00003000 fd:01 6184796 /lib/x86_64-linux-gnu/librt-2.29.so
7fce7cbd1000-7fce7cbd3000 r–p 00007000 fd:01 6184796 /lib/x86_64-linux-gnu/librt-2.29.so
7fce7cbd3000-7fce7cbd4000 r–p 00008000 fd:01 6184796 /lib/x86_64-linux-gnu/librt-2.29.so
7fce7cbd4000-7fce7cbd5000 rw-p 00009000 fd:01 6184796 /lib/x86_64-linux-gnu/librt-2.29.so
7fce7cbd5000-7fce7cbd6000 —p 00000000 00:00 0
7fce7cbd6000-7fce7cbd9000 —p 00000000 00:00 0
7fce7cbd9000-7fce7ccd6000 rw-p 00000000 00:00 0
7fce7ccd6000-7fce7cce5000 r–p 00000000 fd:01 6184783 /lib/x86_64-linux-gnu/libm-2.29.so
7fce7cce5000-7fce7cd8b000 r-xp 0000f000 fd:01 6184783 /lib/x86_64-linux-gnu/libm-2.29.so
7fce7cd8b000-7fce7ce22000 r–p 000b5000 fd:01 6184783 /lib/x86_64-linux-gnu/libm-2.29.so
7fce7ce22000-7fce7ce23000 r–p 0014b000 fd:01 6184783 /lib/x86_64-linux-gnu/libm-2.29.so
7fce7ce23000-7fce7ce24000 rw-p 0014c000 fd:01 6184783 /lib/x86_64-linux-gnu/libm-2.29.so
7fce7ce24000-7fce7da54000 r-xp 00000000 fd:01 4989466 /opt/phaedra/jre/lib/amd64/server/libjvm.so
7fce7da54000-7fce7dc54000 —p 00c30000 fd:01 4989466 /opt/phaedra/jre/lib/amd64/server/libjvm.so
7fce7dc54000-7fce7dd22000 rw-p 00c30000 fd:01 4989466 /opt/phaedra/jre/lib/amd64/server/libjvm.so
7fce7dd22000-7fce7dd67000 rw-p 00000000 00:00 0
7fce7dd67000-7fce7dd8c000 r–p 00000000 fd:01 6184780 /lib/x86_64-linux-gnu/libc-2.29.so
7fce7dd8c000-7fce7deff000 r-xp 00025000 fd:01 6184780 /lib/x86_64-linux-gnu/libc-2.29.so
7fce7deff000-7fce7df48000 r–p 00198000 fd:01 6184780 /lib/x86_64-linux-gnu/libc-2.29.so
7fce7df48000-7fce7df4b000 r–p 001e0000 fd:01 6184780 /lib/x86_64-linux-gnu/libc-2.29.so
7fce7df4b000-7fce7df4e000 rw-p 001e3000 fd:01 6184780 /lib/x86_64-linux-gnu/libc-2.29.so
7fce7df4e000-7fce7df52000 rw-p 00000000 00:00 0
7fce7df52000-7fce7df53000 r–p 00000000 fd:01 6184782 /lib/x86_64-linux-gnu/libdl-2.29.so
7fce7df53000-7fce7df55000 r-xp 00001000 fd:01 6184782 /lib/x86_64-linux-gnu/libdl-2.29.so
7fce7df55000-7fce7df56000 r–p 00003000 fd:01 6184782 /lib/x86_64-linux-gnu/libdl-2.29.so
7fce7df56000-7fce7df57000 r–p 00003000 fd:01 6184782 /lib/x86_64-linux-gnu/libdl-2.29.so
7fce7df57000-7fce7df58000 rw-p 00004000 fd:01 6184782 /lib/x86_64-linux-gnu/libdl-2.29.so
7fce7df58000-7fce7df6d000 r-xp 00000000 fd:01 4989484 /opt/phaedra/jre/lib/amd64/jli/libjli.so
7fce7df6d000-7fce7e16d000 —p 00015000 fd:01 4989484 /opt/phaedra/jre/lib/amd64/jli/libjli.so
7fce7e16d000-7fce7e16e000 rw-p 00015000 fd:01 4989484 /opt/phaedra/jre/lib/amd64/jli/libjli.so
7fce7e16e000-7fce7e175000 r–p 00000000 fd:01 6184794 /lib/x86_64-linux-gnu/libpthread-2.29.so
7fce7e175000-7fce7e184000 r-xp 00007000 fd:01 6184794 /lib/x86_64-linux-gnu/libpthread-2.29.so
7fce7e184000-7fce7e189000 r–p 00016000 fd:01 6184794 /lib/x86_64-linux-gnu/libpthread-2.29.so
7fce7e189000-7fce7e18a000 r–p 0001a000 fd:01 6184794 /lib/x86_64-linux-gnu/libpthread-2.29.so
7fce7e18a000-7fce7e18b000 rw-p 0001b000 fd:01 6184794 /lib/x86_64-linux-gnu/libpthread-2.29.so
7fce7e18b000-7fce7e191000 rw-p 00000000 00:00 0
7fce7e191000-7fce7e195000 r–s 00097000 fd:01 4989520 /opt/phaedra/jre/lib/jsse.jar
7fce7e195000-7fce7e196000 r–s 0000c000 fd:01 4989597 /opt/phaedra/plugins/org.eclipse.equinox.launcher_1.3.200.v201603
18-1642.jar
7fce7e196000-7fce7e199000 r–p 00000000 fd:01 6184789 /lib/x86_64-linux-gnu/libnss_files-2.29.so
7fce7e199000-7fce7e1a0000 r-xp 00003000 fd:01 6184789 /lib/x86_64-linux-gnu/libnss_files-2.29.so
7fce7e1a0000-7fce7e1a2000 r–p 0000a000 fd:01 6184789 /lib/x86_64-linux-gnu/libnss_files-2.29.so
7fce7e1a2000-7fce7e1a3000 r–p 0000b000 fd:01 6184789 /lib/x86_64-linux-gnu/libnss_files-2.29.so
7fce7e1a3000-7fce7e1a4000 rw-p 0000c000 fd:01 6184789 /lib/x86_64-linux-gnu/libnss_files-2.29.so
7fce7e1a4000-7fce7e1ab000 rw-p 00000000 00:00 0
7fce7e1ab000-7fce7e1ac000 r–p 00000000 00:00 0
7fce7e1ac000-7fce7e1ad000 r–p 00000000 fd:01 6184776 /lib/x86_64-linux-gnu/ld-2.29.so
7fce7e1ad000-7fce7e1ce000 r-xp 00001000 fd:01 6184776 /lib/x86_64-linux-gnu/ld-2.29.so
7fce7e1ce000-7fce7e1d6000 r–p 00022000 fd:01 6184776 /lib/x86_64-linux-gnu/ld-2.29.so
7fce7e1d6000-7fce7e1d7000 r–p 00029000 fd:01 6184776 /lib/x86_64-linux-gnu/ld-2.29.so
7fce7e1d7000-7fce7e1d8000 rw-p 0002a000 fd:01 6184776 /lib/x86_64-linux-gnu/ld-2.29.so
7fce7e1d8000-7fce7e1d9000 rw-p 00000000 00:00 0
7ffc14838000-7ffc14859000 rw-p 00000000 00:00 0 [stack]
7ffc148b2000-7ffc148b5000 r–p 00000000 00:00 0 [vvar]
7ffc148b5000-7ffc148b7000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
