I use MySQL database as a docker container. I would like to manage the database via phpMyAdmin image (phpmyadmin/phpmyadmin on Docker.hub). I can build a network and have these two components working together outside of Shinyproxy. But I’d like to put the phpMyAdmin app on the list of application when logging to Shinyproxy. I just don’t know what is the proper command to run the phpmyadmin container. This is what I have in application.yml:
apps:
- name: dbapp
display-name: MySQL application
docker-cmd: ["R", "-e shiny::runApp('/data')"]
docker-image: dbapp
docker-network-connections: ["db-network"]
docker-env-file: db.env
groups: admin
- name: phpmyadmin
display-name: phpmyadmin
docker-cmd: [ "/run.sh", "supervisord", "-n" ]
docker-image: phpmyadmin/phpmyadmin
groups: admin
Networking is done by ‘db-network’, the network used by the database container. The first application is just for testing if all is working properly. It is. I just don’t know what docker-cmd I should use for phpmyadmin application.
Can anyone help me with this?
