Trying to create the function that loads the project into the temporary directory.
This is the line that is causing the problem:
# copy server.R, ui.R, www etc.
# shinyUiDir <- system.file("examples", "01_hello", package = "shiny")
shinyUiDir <- system.file("R", package = "EdaWeb")
I don’t know where my application will install to, so all I need to do is find out what to name my shinyUiDir and this script should work, but given I can’t get my Docker image to build because it is not looking in the R directory, it’s unclear where to build the list of files from. The directory would be wherever the installation directory is, and then inside the R directory.
