Hello all,
I’m trying to use a custom template 2col as published here. This is the tree structure of my shinyproxy setup.
├── 04-custom-html-template
│ └── templates
│ └── 2col
│ ├── assets
│ │ ├── css
│ │ │ └── 2-col-portfolio.css
│ │ └── img
│ └── index.html
├── application.yml
├── shinyproxy-1.1.1.jar
└── shinyproxy.log
My application.yml
file has template path specified as
template-path: ./04-custom-html-template/templates/2col
But when I reload shinyproxy and access the dashboard, it crashes with below output. Any tips what’s going on? The line that sticks out is
Caused by: org.springframework.expression.spel.SpelEvaluationException: EL1008E: Property or field 'id' cannot be found on object of type 'eu.openanalytics.shinyproxy.services.AppService$ShinyApp' - maybe not public?
Error
Status code: 500
Message: Exception evaluating SpringEL expression: "app.id" (index:43)
Stack Trace:
org.thymeleaf.exceptions.TemplateProcessingException: Exception evaluating SpringEL expression: "app.id" (index:43)
at org.thymeleaf.spring4.expression.SpelVariableExpressionEvaluator.evaluate(SpelVariableExpressionEvaluator.java:161)
at org.thymeleaf.standard.expression.VariableExpression.executeVariable(VariableExpression.java:154)
at org.thymeleaf.standard.expression.SimpleExpression.executeSimple(SimpleExpression.java:59)
at org.thymeleaf.standard.expression.Expression.execute(Expression.java:103)
at org.thymeleaf.standard.expression.AdditionExpression.executeAddition(AdditionExpression.java:92)
at org.thymeleaf.standard.expression.ComplexExpression.executeComplex(ComplexExpression.java:55)
at org.thymeleaf.standard.expression.Expression.execute(Expression.java:107)
at org.thymeleaf.standard.expression.Expression.execute(Expression.java:133)
at org.thymeleaf.standard.expression.Expression.execute(Expression.java:120)
at org.thymeleaf.standard.processor.attr.AbstractStandardSingleAttributeModifierAttrProcessor.getTargetAttributeValue(AbstractStandardSingleAttributeModifierAttrProcessor.java:67)
at org.thymeleaf.spring4.processor.attr.SpringHrefAttrProcessor.getTargetAttributeValue(SpringHrefAttrProcessor.java:68)
at org.thymeleaf.processor.attr.AbstractSingleAttributeModifierAttrProcessor.getModifiedAttributeValues(AbstractSingleAttributeModifierAttrProcessor.java:59)
at org.thymeleaf.processor.attr.AbstractAttributeModifierAttrProcessor.processAttribute(AbstractAttributeModifierAttrProcessor.java:62)
at org.thymeleaf.processor.attr.AbstractAttrProcessor.doProcess(AbstractAttrProcessor.java:87)
at org.thymeleaf.processor.AbstractProcessor.process(AbstractProcessor.java:212)
at org.thymeleaf.dom.Node.applyNextProcessor(Node.java:1017)
at org.thymeleaf.dom.Node.processNode(Node.java:972)
at org.thymeleaf.dom.NestableNode.computeNextChild(NestableNode.java:695)
at org.thymeleaf.dom.NestableNode.doAdditionalProcess(NestableNode.java:668)
at org.thymeleaf.dom.Node.processNode(Node.java:990)
at org.thymeleaf.dom.Document.process(Document.java:93)
at org.thymeleaf.TemplateEngine.process(TemplateEngine.java:1155)
at org.thymeleaf.TemplateEngine.process(TemplateEngine.java:1060)
at org.thymeleaf.TemplateEngine.process(TemplateEngine.java:1011)
at org.thymeleaf.spring4.view.ThymeleafView.renderFragment(ThymeleafView.java:335)
at org.thymeleaf.spring4.view.ThymeleafView.render(ThymeleafView.java:190)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1282)
at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1037)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:980)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:85)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:64)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99)
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:105)
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:81)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:211)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:809)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1135)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:844)
at org.springframework.expression.spel.ast.PropertyOrFieldReference.readProperty(PropertyOrFieldReference.java:224)
at org.springframework.expression.spel.ast.PropertyOrFieldReference.getValueInternal(PropertyOrFieldReference.java:94)
at org.springframework.expression.spel.ast.PropertyOrFieldReference.access$000(PropertyOrFieldReference.java:46)
at org.springframework.expression.spel.ast.PropertyOrFieldReference$AccessorLValue.getValue(PropertyOrFieldReference.java:375)
at org.springframework.expression.spel.ast.CompoundExpression.getValueInternal(CompoundExpression.java:88)
at org.springframework.expression.spel.ast.SpelNodeImpl.getValue(SpelNodeImpl.java:120)
at org.springframework.expression.spel.standard.SpelExpression.getValue(SpelExpression.java:267)
at org.thymeleaf.spring4.expression.SpelVariableExpressionEvaluator.evaluate(SpelVariableExpressionEvaluator.java:139)
... 132 more
