Hello everyone,
I use shinyproxy 2.02,
Some people have a gray screen when they try to connect to the app. In shinyproxy.log, i find this error:
2018-09-04 08:25:20.500 ERROR 1 --- [XNIO-2 I/O-2] io.undertow.request : UT005071: Undertow request failed HttpServerExchange{ GET /endpoint/dde2e27e-9599-4b9e-888a-7e180e9189f7/ reques$
java.nio.channels.UnresolvedAddressException: null
at sun.nio.ch.Net.checkAddress(Net.java:101) ~[na:1.8.0_171]
at sun.nio.ch.SocketChannelImpl.connect(SocketChannelImpl.java:622) ~[na:1.8.0_171]
at org.xnio.nio.WorkerThread.openTcpStreamConnection(WorkerThread.java:266) [xnio-nio-3.3.8.Final.jar!/:3.3.8.Final]
at org.xnio.XnioIoThread.openStreamConnection(XnioIoThread.java:224) ~[xnio-api-3.3.8.Final.jar!/:3.3.8.Final]
at io.undertow.client.http.HttpClientProvider.connect(HttpClientProvider.java:105) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.client.UndertowClient.connect(UndertowClient.java:157) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.handlers.proxy.ProxyConnectionPool.openConnection(ProxyConnectionPool.java:273) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.handlers.proxy.ProxyConnectionPool.connect(ProxyConnectionPool.java:527) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.handlers.proxy.LoadBalancingProxyClient.getConnection(LoadBalancingProxyClient.java:301) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at eu.openanalytics.containerproxy.util.ProxyMappingManager$1.getConnection(ProxyMappingManager.java:70) ~[containerproxy-0.3.1-SNAPSHOT.jar!/:0.3.1-SNAPSHOT]
at io.undertow.server.handlers.proxy.ProxyHandler$ProxyClientHandler.run(ProxyHandler.java:310) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.util.SameThreadExecutor.execute(SameThreadExecutor.java:35) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:353) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.protocol.http.HttpReadListener.handleEventWithNoRunningRequest(HttpReadListener.java:255) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.protocol.http.HttpReadListener.handleEvent(HttpReadListener.java:136) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at io.undertow.server.protocol.http.HttpReadListener.handleEvent(HttpReadListener.java:59) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
at org.xnio.ChannelListeners.invokeChannelListener(ChannelListeners.java:92) [xnio-api-3.3.8.Final.jar!/:3.3.8.Final]
at org.xnio.conduits.ReadReadyHandler$ChannelListenerHandler.readReady(ReadReadyHandler.java:66) [xnio-api-3.3.8.Final.jar!/:3.3.8.Final]
at org.xnio.nio.NioSocketConduit.handleReady(NioSocketConduit.java:88) [xnio-nio-3.3.8.Final.jar!/:3.3.8.Final]
at org.xnio.nio.WorkerThread.run(WorkerThread.java:561) [xnio-nio-3.3.8.Final.jar!/:3.3.8.Final]
Has someone already had this problem ?
Thank,
