Hey guys,
I tried to follow your amazing guide to get started with shinyproxy (https://www.shinyproxy.io/getting-started/).
I’m using an amazon Linux 2018.03 instance. I installed java first and my java version is:
openjdk version "1.8.0_222" OpenJDK Runtime Environment (build 1.8.0_222-b10) OpenJDK 64-Bit Server VM (build 25.222-b10, mixed mode)
And then we installed the docker by running sudo install docker and sudo service docker status returns docker (pid 2890) is running.... But on Amazon Linux server there is no /etc/systemd folder, so I can’t change the ExecStart= part.
And if I pull your demo image using sudo docker pull openanalytics/shinyproxy-demo and run java -jar shinyproxy-2.3.0.jar (where your default application.yml file is in the same folder, the only thing I changed was the port, from 8080 to 2555), this is the output on the console:
:: Spring Boot :: (v2.0.0.RELEASE)
2019-11-08 01:15:14.264 INFO 4539 --- [ main] e.o.c.ContainerProxyApplication : Starting ContainerProxyApplication v0.8.3 on ip-10-0-0-32 with PID 4539 (/home/ec2-user/shinyproxy-2.3.0.jar started by root in /home/ec2-user)
2019-11-08 01:15:14.268 INFO 4539 --- [ main] e.o.c.ContainerProxyApplication : No active profile set, falling back to default profiles: default
2019-11-08 01:15:14.319 INFO 4539 --- [ main] ConfigServletWebServerApplicationContext : Refreshing org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@69d9c55: startup date [Fri Nov 08 01:15:14 UTC 2019]; root of context hierarchy
2019-11-08 01:15:15.346 INFO 4539 --- [ main] f.a.AutowiredAnnotationBeanPostProcessor : JSR-330 'javax.inject.Inject' annotation found and supported for autowiring
2019-11-08 01:15:16.230 INFO 4539 --- [ main] org.xnio : XNIO version 3.3.8.Final
2019-11-08 01:15:16.247 INFO 4539 --- [ main] org.xnio.nio : XNIO NIO Implementation Version 3.3.8.Final
2019-11-08 01:15:16.391 WARN 4539 --- [ main] io.undertow.websockets.jsr : UT026009: XNIO worker was not set on WebSocketDeploymentInfo, the default worker will be used
2019-11-08 01:15:16.391 WARN 4539 --- [ main] io.undertow.websockets.jsr : UT026010: Buffer pool was not set on WebSocketDeploymentInfo, the default pool will be used
2019-11-08 01:15:16.418 INFO 4539 --- [ main] io.undertow.servlet : Initializing Spring embedded WebApplicationContext
2019-11-08 01:15:16.418 INFO 4539 --- [ main] o.s.web.context.ContextLoader : Root WebApplicationContext: initialization completed in 2099 ms
2019-11-08 01:15:16.582 INFO 4539 --- [ main] o.s.b.w.servlet.FilterRegistrationBean : Mapping filter: 'characterEncodingFilter' to: [/*]
2019-11-08 01:15:16.583 INFO 4539 --- [ main] o.s.b.w.servlet.FilterRegistrationBean : Mapping filter: 'requestContextFilter' to: [/*]
2019-11-08 01:15:16.584 INFO 4539 --- [ main] .s.DelegatingFilterProxyRegistrationBean : Mapping filter: 'springSecurityFilterChain' to: [/*]
2019-11-08 01:15:16.584 INFO 4539 --- [ main] o.s.boot.web.servlet.RegistrationBean : Filter orderedHiddenHttpMethodFilter was not registered (disabled)
2019-11-08 01:15:16.584 INFO 4539 --- [ main] o.s.boot.web.servlet.RegistrationBean : Filter orderedHttpPutFormContentFilter was not registered (disabled)
2019-11-08 01:15:16.584 INFO 4539 --- [ main] o.s.b.w.servlet.ServletRegistrationBean : Servlet dispatcherServlet mapped to [/]
2019-11-08 01:15:16.839 INFO 4539 --- [ main] e.o.c.stat.StatCollectorRegistry : Disabled. Usage statistics will not be processed.
2019-11-08 01:15:17.067 INFO 4539 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/css/**'], []
2019-11-08 01:15:17.068 INFO 4539 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/img/**'], []
2019-11-08 01:15:17.068 INFO 4539 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/js/**'], []
2019-11-08 01:15:17.068 INFO 4539 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/assets/**'], []
2019-11-08 01:15:17.068 INFO 4539 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/webjars/**'], []
2019-11-08 01:15:17.204 INFO 4539 --- [ main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: org.springframework.security.web.util.matcher.AnyRequestMatcher@1, [org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter@1530c739, org.springframework.security.web.context.SecurityContextPersistenceFilter@368247b9, org.springframework.security.web.header.HeaderWriterFilter@6c1a5b54, org.springframework.security.web.authentication.logout.LogoutFilter@63376bed, org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter@6e6f2380, org.springframework.security.web.authentication.www.BasicAuthenticationFilter@5b1669c0, org.springframework.security.web.savedrequest.RequestCacheAwareFilter@1a942c18, org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter@738dc9b, org.springframework.security.web.authentication.AnonymousAuthenticationFilter@78e4deb0, org.springframework.security.web.session.SessionManagementFilter@60099951, org.springframework.security.web.access.ExceptionTranslationFilter@45099dd3, org.springframework.security.web.access.intercept.FilterSecurityInterceptor@7526515b]
2019-11-08 01:15:17.247 WARN 4539 --- [ main] org.thymeleaf.templatemode.TemplateMode : [THYMELEAF][main] Template Mode 'HTML5' is deprecated. Using Template Mode 'HTML' instead.
2019-11-08 01:15:17.628 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerAdapter : Looking for @ControllerAdvice: org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@69d9c55: startup date [Fri Nov 08 01:15:14 UTC 2019]; root of context hierarchy
2019-11-08 01:15:17.711 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/app/*],methods=[GET]}" onto public java.lang.String eu.openanalytics.shinyproxy.controllers.AppController.app(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2019-11-08 01:15:17.713 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/app_direct/**]}" onto public void eu.openanalytics.shinyproxy.controllers.AppController.appDirect(javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2019-11-08 01:15:17.713 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/app/*],methods=[POST]}" onto public java.util.Map<java.lang.String, java.lang.String> eu.openanalytics.shinyproxy.controllers.AppController.startApp(javax.servlet.http.HttpServletRequest)
2019-11-08 01:15:17.714 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/issue],methods=[POST]}" onto public java.lang.String eu.openanalytics.shinyproxy.controllers.IssueController.postIssue(javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2019-11-08 01:15:17.715 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/admin]}" onto private java.lang.String eu.openanalytics.shinyproxy.controllers.AdminController.admin(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2019-11-08 01:15:17.715 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/]}" onto private java.lang.Object eu.openanalytics.shinyproxy.controllers.IndexController.index(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2019-11-08 01:15:17.717 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy/{proxyId}],methods=[GET],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.getProxy(java.lang.String)
2019-11-08 01:15:17.717 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxyspec],methods=[GET],produces=[application/json]}" onto public java.util.List<eu.openanalytics.containerproxy.model.spec.ProxySpec> eu.openanalytics.containerproxy.api.ProxyController.listProxySpecs()
2019-11-08 01:15:17.718 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy],methods=[GET],produces=[application/json]}" onto public java.util.List<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.listProxies()
2019-11-08 01:15:17.718 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy/{proxyId}],methods=[DELETE],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<java.lang.String> eu.openanalytics.containerproxy.api.ProxyController.stopProxy(java.lang.String)
2019-11-08 01:15:17.719 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxyspec/{proxySpecId}],methods=[GET],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.spec.ProxySpec> eu.openanalytics.containerproxy.api.ProxyController.getProxySpec(java.lang.String)
2019-11-08 01:15:17.719 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy],methods=[POST],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.startProxy(eu.openanalytics.containerproxy.model.spec.ProxySpec)
2019-11-08 01:15:17.720 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy/{proxySpecId}],methods=[POST],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.startProxy(java.lang.String,java.util.Set<eu.openanalytics.containerproxy.model.runtime.RuntimeSetting>)
2019-11-08 01:15:17.721 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/login],methods=[GET]}" onto public java.lang.Object eu.openanalytics.containerproxy.ui.LoginController.getLoginPage(java.util.Optional<java.lang.String>,org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2019-11-08 01:15:17.721 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/route/**]}" onto public void eu.openanalytics.containerproxy.api.ProxyRouteController.route(javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2019-11-08 01:15:17.725 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/error],consumes=[application/json],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<java.util.Map<java.lang.String, java.lang.Object>> eu.openanalytics.containerproxy.ui.ErrorController.error(javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2019-11-08 01:15:17.725 INFO 4539 --- [ main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/error],produces=[text/html]}" onto public java.lang.String eu.openanalytics.containerproxy.ui.ErrorController.handleError(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2019-11-08 01:15:17.780 INFO 4539 --- [ main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/assets/**] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2019-11-08 01:15:17.781 INFO 4539 --- [ main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/webjars/**] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2019-11-08 01:15:17.781 INFO 4539 --- [ main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/**] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2019-11-08 01:15:17.800 INFO 4539 --- [ main] .m.m.a.ExceptionHandlerExceptionResolver : Detected @ExceptionHandler methods in baseController.RestErrorHandler
2019-11-08 01:15:17.834 INFO 4539 --- [ main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/**/favicon.ico] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2019-11-08 01:15:17.951 INFO 4539 --- [ main] o.s.b.a.w.s.WelcomePageHandlerMapping : Adding welcome page template: index
2019-11-08 01:15:18.059 INFO 4539 --- [ main] o.s.l.c.support.AbstractContextSource : Property 'userDn' not set - anonymous context will be used for read-write operations
2019-11-08 01:15:18.230 INFO 4539 --- [ main] o.s.j.e.a.AnnotationMBeanExporter : Registering beans for JMX exposure on startup
2019-11-08 01:15:18.232 INFO 4539 --- [ main] o.s.j.e.a.AnnotationMBeanExporter : Bean with name 'dataSource' has been autodetected for JMX exposure
2019-11-08 01:15:18.237 INFO 4539 --- [ main] o.s.j.e.a.AnnotationMBeanExporter : Located MBean 'dataSource': registering with JMX server as MBean [com.zaxxer.hikari:name=dataSource,type=HikariDataSource]
2019-11-08 01:15:18.304 INFO 4539 --- [ main] o.s.b.w.e.u.UndertowServletWebServer : Undertow started on port(s) 2555 (http) with context path ''
2019-11-08 01:15:18.307 INFO 4539 --- [ main] e.o.c.ContainerProxyApplication : Started ContainerProxyApplication in 4.563 seconds (JVM running for 5.189)
^C2019-11-08 01:17:05.024 INFO 4539 --- [ Thread-2] ConfigServletWebServerApplicationContext : Closing org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@69d9c55: startup date [Fri Nov 08 01:15:14 UTC 2019]; root of context hierarchy
2019-11-08 01:17:05.027 INFO 4539 --- [ Thread-2] o.s.j.e.a.AnnotationMBeanExporter : Unregistering JMX-exposed beans on shutdown
And I can’t access the shiny proxy by typing my server_IP:2555 in my browser (the port 2555 is open in my security group).
EDIT: I think I found the docker config file in /etc/sysconfig/docker and the content there is:
# The max number of open files for the daemon itself, and all
# running containers. The default value of 1048576 mirrors the value
# used by the systemd service unit.
DAEMON_MAXFILES=1048576
# Additional startup options for the Docker daemon, for example:
# OPTIONS="--ip-forward=true --iptables=true"
# By default we limit the number of open files per container
OPTIONS="--default-ulimit nofile=1024:4096"
# How many seconds the sysvinit script waits for the pidfile to appear
# when starting the daemon.
DAEMON_PIDFILE_TIMEOUT=10
Thanks in advance,
Silvano
