I’m not able to get my Docker image to build. I created a package EdaWeb_0.1.tar.gz
that follows the same directory structure of the shinyproxy-demo
. Here is the error I get when I try to build the Docker file. All my R files are in the R directory of the project, just like the shinyproxy-demo app.
Step 6 : RUN R CMD INSTALL /root/EdaWeb_0.1.tar.gz
—> Running in 5e4344018376
e[91m* installing to library ‘/usr/local/lib/R/site-library’
e[0me[91m* installing source package ‘EdaWeb’ …
e[0me[91m** R
e[0me[91m** preparing package for lazy loading
e[0me[91mWarning in file(filename, “r”, encoding = encoding) :
e[0me[91m cannot open file ‘MessageHelperFunctions.R’: No such file or directory
e[0me[91mError in file(filename, “r”, encoding = encoding) :
cannot open the connection
e[0me[91mError : unable to load R code in package ‘EdaWeb’
e[0me[91mERROR: lazy loading failed for package ‘EdaWeb’
e[0me[91m* removing ‘/usr/local/lib/R/site-library/EdaWeb’
e[0mRemoving intermediate container 5e4344018376
The command ‘/bin/sh -c R CMD INSTALL /root/EdaWeb_0.1.tar.gz’ returned a non-zero code: 1
All of my files are in the EdaWeb/R folder, but the Docker installation script is not looking there for the R files.
