Rdepot 2.6.2 – Replace option does not update package tar.gz
With version 2.6.2 of rdepot, we noticed that when trying to overwrite an existing R package (same version number) by explicitly checking the “replace” option in the graphical interface, it doesn’t seem to work as expected. Everything appears to go smoothly, BUT the tar.gz file made available is not updated.
We also tried with a curl request and encountered the same issue.
Is this a known bug?
Hi Vincent,
Thank you for notifying us about the problem! Indeed, this is a bug. We will include a fix for this in the new release of RDepot. I will report back when it is released. Stay tuned!
Best regards,
Daria
Hi Vincent,
The newest release of RDepot, version 2.7.0, fixes this bug.
More information can be found here: Downloads | RDepot.
Please give it a try and report back if you encounter any issues.
Thank you,
Jonas
