I have successfully installed RDepot using a docker-compose file on a test server – everything works fine, thank you. I’m now trying to work with the API, but I’m stuck because all my attempts result in a 401 error (both via Swagger and when using a curl command from the server).
{"status":"ERROR","code":401,"message":"Cannot perform this request because user is not authenticated.","messageCode":"error.user.not.authenticated","data":null}
My first question is: is the expected request as follows?
curl -X GET 'http://xx.xx.xx.xx.xx/backend/api/v2/manager/repository-maintainers?page=0&size=20' \
-H 'accept: application/json' \
-H 'X-Auth-Token: <my_token>'
or should it be this one?
-H 'Authorization: Bearer <my_token>'
My second question is: does the <my_token> correspond to an “access token” generated from the web interface?
Below is the docker-compose file I’m using:
services:
image: nginx:alpine
container_name: oa-rdepot-proxy
restart: unless-stopped
volumes:
- ./docker/compose/proxy/nginx.conf:/etc/nginx/nginx.conf:ro
- ./docker/compose/proxy/rdepot.conf:/etc/nginx/sites-enabled/rdepot:ro
- ./repository:/opt/rdepot/repo/:ro
- ./logs:/var/log/nginx/
ports:
- ${RDEPOT_PORT:-80}:80
depends_on:
- backend
- repo
- frontend
networks:
- oa-rdepot
db:
image: postgres:alpine
hostname: oa-rdepot-db
container_name: oa-rdepot-db
environment:
- POSTGRES_DB=rdepot
- POSTGRES_USER=rdepot
- POSTGRES_PASSWORD=mysecretpassword
networks:
- oa-rdepot
volumes:
- ./pgdata:/var/lib/postgresql/data
backend:
image: openanalytics/rdepot-app:2.5.1
hostname: oa-rdepot-backend
container_name: oa-rdepot-backend
user: "2000:2000"
volumes:
- ./repositories:/opt/rdepot/repositories/
- ./snapshots:/opt/rdepot/generated/
- ./queue:/opt/rdepot/new/
- ./repository/declared_repositories:/opt/rdepot/declared_repositories
# - ./repository:/opt/rdepot/
- ./docker/compose/backend/application.yaml:/opt/rdepot/application.yml
networks:
- oa-rdepot
depends_on:
- db
environment:
- DB_URL=jdbc:postgresql://oa-rdepot-db:5432/rdepot
- DB_USERNAME=rdepot
- DB_PASSWORD=mysecretpassword
- ALLOWED-ORIGIN=http://xx.xx.xx.xx.xx:${RDEPOT_PORT:-80}
healthcheck:
test: ["CMD-SHELL", "if [ \"$$(curl -I localhost:8080/backend 2>/dev/null | grep HTTP/1.1 | cut -d\" \" -f2)\" != \"302\" ]; then exit 1; else exit 0; fi;"]
interval: 10s
timeout: 10s
retries: 10
repo:
user: "2000:2000"
image: openanalytics/rdepot-repo:2.5.1
hostname: oa-rdepot-repo
container_name: oa-rdepot-repo
volumes:
- ./docker/compose/repo/application.yaml:/opt/repo/application.yml
networks:
- oa-rdepot
frontend:
container_name: oa-rdepot-frontend
image: openanalytics/rdepot-client:2.5.1
networks:
- oa-rdepot
environment:
- VITE_DEV_MODE=false
- VITE_LOGIN_SIMPLE=true
- VITE_LOGIN_OIDC=false
- VITE_URL_PREFIX=/
- VITE_SERVER_ADDRESS=http://xx.xx.xx.xx.xx:${RDEPOT_PORT:-80}/backend
networks:
oa-rdepot:
And here is the backend/application.yml I am using:
api-token:
secret: SecretKeyToGenJWTs
issuer: RDepot
audience:
- RDepot
lifetime: 60
allowed-origin: "*"
servlet:
context-path: /backend
default-user-configuration:
language: en-US
theme: dark
page-size: 10
supported-languages:
- en-US
- pl-PL
supported-themes:
- light
- dark
declarative: true
additional-repository-configs:
paths:
- /opt/rdepot/declared_repositories
level:
eu:
openanalytics:
rdepot: INFO
# Email related properties
email:
enabled: false
password:
username:
smtp:
host:
port:
auth:
starttls:
# Authentication related properties
app:
simple:
- login: einstein
password: testpassword
- login: tesla
- login: galieleo
- login: newton
- login: newbie
- login: doe
default:
admins:
- einstein
# Database related properties
db:
driver: org.postgresql.Driver
url: jdbc:postgresql://oa-rdepot-db:5432/rdepot
username: rdepot
password: mysecretpassword
# Hibernate related properties
hibernate:
dialect: org.hibernate.dialect.PostgreSQLDialect
show_sql: false
# Liquibase related properties
spring:
liquibase:
user: rdepot
enabled: true
springdoc:
pathsToMatch: /api/v2/**
api-docs:
path: /v2/api-docs
swagger-ui:
path: /docs/api.html
disable-swagger-default-url: false
url: /v2/api-docs
display-query-params: true
default-produces-media-type: application/json
Thank you for your help.
