I have created a dockerized shiny app with below syntax
docker build -t cm .; docker run -v /opt/lampp/htdocs/CM/www:/www --restart=always -d -p 6363:6363 cm
With this my Shiny app is working fine in http://ip-address:6363
Last few lines of the underlying docker file is
RUN mkdir /root/cm
COPY CM /root/cm
EXPOSE 6363
CMD ["R", "-e", "shiny::runApp('/root/cm')"]
Now I wanted to run this app with Shiny-proxy so that many concurrent users can use this simultaneously
So I created below yml file and placed it same folder where the dockerfile is based.
logo-url: http://www.openanalytics.eu/sites/www.openanalytics.eu/themes/oa/logo.png
heartbeat-timeout: 60000
authentication: none
admin-groups: scientists
# Example: 'simple' authentication configuration
- name: jack
password: password
groups: scientists
- name: jeff
password: password
groups: mathematicians
# Example: 'ldap' authentication configuration
ldap:
url: ldap://ldap.forumsys.com:389/dc=example,dc=com
user-dn-pattern: uid={0}
group-search-base:
group-search-filter: (uniqueMember={0})
manager-dn: cn=read-only-admin,dc=example,dc=com
manager-password: password
# Docker configuration
#url: http://localhost:2375
#container-protocol: http
#internal-networking: true
cert-path: /home/none
url: http://127.0.0.1:2375
host: 127.0.0.1
- id: cm
display-name: My Application
description: My Application
container-cmd: ["R", "-e", "shiny::runApp('/root/cm')"]
container-image: cm
port: 6363
To run my app with shiny-proxy, I used below syntax
java -jar /opt/shinyproxy/shinyproxy.jar
(I am in the same folder where my Dockerfile/application/yml file is based)
But when I typed the address in browser http://ip-address:8080/app/cm, I failed to run my app. The error I see is below-
# Error
**Status code:** 500
**Message:** Container did not respond in time
**Stack Trace:**
eu.openanalytics.containerproxy.ContainerProxyException: Container did not respond in time
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.startProxy(AbstractContainerBackend.java:118)
at eu.openanalytics.containerproxy.service.ProxyService.startProxy(ProxyService.java:213)
at eu.openanalytics.shinyproxy.controllers.AppController.getOrStart(AppController.java:109)
at eu.openanalytics.shinyproxy.controllers.AppController.startApp(AppController.java:68)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:209)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:136)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:870)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:776)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:991)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:925)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:978)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:881)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:855)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:64)
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:94)
at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:159)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:336)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
I have searched and tried with many posts here with similar issue, but unable to run my app.
Any pointer toward resolving this problem will be highly appreciated.
Thanks,
