I have spent so long working on this and have not come any closer to understanding the issue. My docker container works great, and shiny proxy starts with no errors. However, the page rendered by shiny proxy is just white with the title bar, there is no content. Does anyone know why this could be happening? This is my shinyproxy.log file. I have looked it over endlessly but can’t find the source of the issue.
2018-09-21 12:20:57.894 INFO 14369 --- [main] ConfigServletWebServerApplicationContext : Closing org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@67b64c45: startup date [Fri Sep 21 12:20:54 EDT 2018]; root of context hierarchy
2018-09-21 12:20:57.896 INFO 14369 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Unregistering JMX-exposed beans on shutdown
2018-09-21 12:20:57.897 INFO 14369 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Unregistering JMX-exposed beans
2018-09-21 12:24:21.394 INFO 14663 --- [main] e.o.c.ContainerProxyApplication : Starting ContainerProxyApplication v0.5.0 on elysium with PID 14663 (/home/corey/Dropbox/CPCT/shinyproxy/shinyproxy-2.0.4.jar started by corey in /home/corey/Dropbox/CPCT/shinyproxy)
2018-09-21 12:24:21.397 INFO 14663 --- [main] e.o.c.ContainerProxyApplication : No active profile set, falling back to default profiles: default
2018-09-21 12:24:21.451 INFO 14663 --- [main] ConfigServletWebServerApplicationContext : Refreshing org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@6fadae5d: startup date [Fri Sep 21 12:24:21 EDT 2018]; root of context hierarchy
2018-09-21 12:24:22.452 INFO 14663 --- [main] f.a.AutowiredAnnotationBeanPostProcessor : JSR-330 'javax.inject.Inject' annotation found and supported for autowiring
2018-09-21 12:24:23.156 INFO 14663 --- [main] org.xnio : XNIO version 3.3.8.Final
2018-09-21 12:24:23.174 INFO 14663 --- [main] org.xnio.nio : XNIO NIO Implementation Version 3.3.8.Final
2018-09-21 12:24:23.241 WARN 14663 --- [main] io.undertow.websockets.jsr : UT026009: XNIO worker was not set on WebSocketDeploymentInfo, the default worker will be used
2018-09-21 12:24:23.241 WARN 14663 --- [main] io.undertow.websockets.jsr : UT026010: Buffer pool was not set on WebSocketDeploymentInfo, the default pool will be used
2018-09-21 12:24:23.259 INFO 14663 --- [main] io.undertow.servlet : Initializing Spring embedded WebApplicationContext
2018-09-21 12:24:23.260 INFO 14663 --- [main] o.s.web.context.ContextLoader : Root WebApplicationContext: initialization completed in 1809 ms
2018-09-21 12:24:23.443 INFO 14663 --- [main] o.s.b.w.servlet.FilterRegistrationBean : Mapping filter: 'characterEncodingFilter' to: [/*]
2018-09-21 12:24:23.444 INFO 14663 --- [main] o.s.b.w.servlet.FilterRegistrationBean : Mapping filter: 'hiddenHttpMethodFilter' to: [/*]
2018-09-21 12:24:23.444 INFO 14663 --- [main] o.s.b.w.servlet.FilterRegistrationBean : Mapping filter: 'httpPutFormContentFilter' to: [/*]
2018-09-21 12:24:23.444 INFO 14663 --- [main] o.s.b.w.servlet.FilterRegistrationBean : Mapping filter: 'requestContextFilter' to: [/*]
2018-09-21 12:24:23.445 INFO 14663 --- [main] .s.DelegatingFilterProxyRegistrationBean : Mapping filter: 'springSecurityFilterChain' to: [/*]
2018-09-21 12:24:23.445 INFO 14663 --- [main] o.s.b.w.servlet.ServletRegistrationBean : Servlet dispatcherServlet mapped to [/]
2018-09-21 12:24:23.673 INFO 14663 --- [main] e.o.c.stat.StatCollectorRegistry : Disabled. Usage statistics will not be processed.
2018-09-21 12:24:23.856 INFO 14663 --- [main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/css/**'], []
2018-09-21 12:24:23.857 INFO 14663 --- [main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/img/**'], []
2018-09-21 12:24:23.857 INFO 14663 --- [main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/js/**'], []
2018-09-21 12:24:23.857 INFO 14663 --- [main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/assets/**'], []
2018-09-21 12:24:23.857 INFO 14663 --- [main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: Ant [pattern='/webjars/**'], []
2018-09-21 12:24:23.930 INFO 14663 --- [main] o.s.s.web.DefaultSecurityFilterChain : Creating filter chain: org.springframework.security.web.util.matcher.AnyRequestMatcher@1, [org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter@1cbb87f3, org.springframework.security.web.context.SecurityContextPersistenceFilter@b62d79, org.springframework.security.web.header.HeaderWriterFilter@51dcb805, org.springframework.security.web.authentication.logout.LogoutFilter@34f5090e, org.springframework.security.web.savedrequest.RequestCacheAwareFilter@5ace1ed4, org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter@4e096385, org.springframework.security.web.authentication.AnonymousAuthenticationFilter@1a4013, org.springframework.security.web.session.SessionManagementFilter@cad498c, org.springframework.security.web.access.ExceptionTranslationFilter@732c2a62]
2018-09-21 12:24:23.960 WARN 14663 --- [main] org.thymeleaf.templatemode.TemplateMode : [THYMELEAF][main] Template Mode 'HTML5' is deprecated. Using Template Mode 'HTML' instead.
2018-09-21 12:24:24.309 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerAdapter : Looking for @ControllerAdvice: org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@6fadae5d: startup date [Fri Sep 21 12:24:21 EDT 2018]; root of context hierarchy
2018-09-21 12:24:24.395 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/app/*],methods=[GET]}" onto public java.lang.String eu.openanalytics.shinyproxy.controllers.AppController.app(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2018-09-21 12:24:24.396 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/app/*],methods=[POST]}" onto public java.util.Map<java.lang.String, java.lang.String> eu.openanalytics.shinyproxy.controllers.AppController.startApp(javax.servlet.http.HttpServletRequest)
2018-09-21 12:24:24.396 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/app_direct/*],methods=[GET]}" onto public java.lang.Object eu.openanalytics.shinyproxy.controllers.AppController.appDirect(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2018-09-21 12:24:24.397 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/]}" onto private java.lang.String eu.openanalytics.shinyproxy.controllers.IndexController.index(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2018-09-21 12:24:24.398 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/issue],methods=[POST]}" onto public java.lang.String eu.openanalytics.shinyproxy.controllers.IssueController.postIssue(javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2018-09-21 12:24:24.398 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/admin]}" onto private java.lang.String eu.openanalytics.shinyproxy.controllers.AdminController.admin(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2018-09-21 12:24:24.401 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/error],produces=[text/html]}" onto public java.lang.String eu.openanalytics.containerproxy.ui.ErrorController.handleError(org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2018-09-21 12:24:24.401 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/error],consumes=[application/json],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<java.util.Map<java.lang.String, java.lang.Object>> eu.openanalytics.containerproxy.ui.ErrorController.error(javax.servlet.http.HttpServletRequest,javax.servlet.http.HttpServletResponse)
2018-09-21 12:24:24.403 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy/{proxyId}],methods=[GET],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.getProxy(java.lang.String)
2018-09-21 12:24:24.404 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxyspec/{proxySpecId}],methods=[GET],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.spec.ProxySpec> eu.openanalytics.containerproxy.api.ProxyController.getProxySpec(java.lang.String)
2018-09-21 12:24:24.404 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy/{proxySpecId}],methods=[POST],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.startProxy(java.lang.String,java.util.Set<eu.openanalytics.containerproxy.model.runtime.RuntimeSetting>)
2018-09-21 12:24:24.404 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy],methods=[POST],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.startProxy(eu.openanalytics.containerproxy.model.spec.ProxySpec)
2018-09-21 12:24:24.405 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxyspec],methods=[GET],produces=[application/json]}" onto public java.util.List<eu.openanalytics.containerproxy.model.spec.ProxySpec> eu.openanalytics.containerproxy.api.ProxyController.listProxySpecs()
2018-09-21 12:24:24.405 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy/{proxyId}],methods=[DELETE],produces=[application/json]}" onto public org.springframework.http.ResponseEntity<java.lang.String> eu.openanalytics.containerproxy.api.ProxyController.stopProxy(java.lang.String)
2018-09-21 12:24:24.406 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/api/proxy],methods=[GET],produces=[application/json]}" onto public java.util.List<eu.openanalytics.containerproxy.model.runtime.Proxy> eu.openanalytics.containerproxy.api.ProxyController.listProxies()
2018-09-21 12:24:24.408 INFO 14663 --- [main] s.w.s.m.m.a.RequestMappingHandlerMapping : Mapped "{[/login],methods=[GET]}" onto public java.lang.Object eu.openanalytics.containerproxy.ui.LoginController.getLoginPage(java.util.Optional<java.lang.String>,org.springframework.ui.ModelMap,javax.servlet.http.HttpServletRequest)
2018-09-21 12:24:24.452 INFO 14663 --- [main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/assets/**] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2018-09-21 12:24:24.452 INFO 14663 --- [main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/webjars/**] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2018-09-21 12:24:24.452 INFO 14663 --- [main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/**] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2018-09-21 12:24:24.475 INFO 14663 --- [main] .m.m.a.ExceptionHandlerExceptionResolver : Detected @ExceptionHandler methods in baseController.RestErrorHandler
2018-09-21 12:24:24.511 INFO 14663 --- [main] o.s.w.s.handler.SimpleUrlHandlerMapping : Mapped URL path [/**/favicon.ico] onto handler of type [class org.springframework.web.servlet.resource.ResourceHttpRequestHandler]
2018-09-21 12:24:24.621 INFO 14663 --- [main] o.s.b.a.w.s.WelcomePageHandlerMapping : Adding welcome page template: index
2018-09-21 12:24:24.710 INFO 14663 --- [main] o.s.l.c.support.AbstractContextSource : Property 'userDn' not set - anonymous context will be used for read-write operations
2018-09-21 12:24:24.851 INFO 14663 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Registering beans for JMX exposure on startup
2018-09-21 12:24:24.852 INFO 14663 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Bean with name 'dataSource' has been autodetected for JMX exposure
2018-09-21 12:24:24.858 INFO 14663 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Located MBean 'dataSource': registering with JMX server as MBean [com.zaxxer.hikari:name=dataSource,type=HikariDataSource]
2018-09-21 12:24:24.933 INFO 14663 --- [main] o.s.b.w.e.u.UndertowServletWebServer : Undertow started on port(s) 4443 (http) with context path ''
2018-09-21 12:24:24.935 INFO 14663 --- [main] e.o.c.ContainerProxyApplication : Started ContainerProxyApplication in 4.002 seconds (JVM running for 4.517)
2018-09-21 12:24:32.603 INFO 14663 --- [XNIO-2 task-1] io.undertow.servlet : Initializing Spring FrameworkServlet 'dispatcherServlet'
2018-09-21 12:24:32.603 INFO 14663 --- [XNIO-2 task-1] o.s.web.servlet.DispatcherServlet : FrameworkServlet 'dispatcherServlet': initialization started
2018-09-21 12:24:32.626 INFO 14663 --- [XNIO-2 task-1] o.s.web.servlet.DispatcherServlet : FrameworkServlet 'dispatcherServlet': initialization completed in 22 ms
2018-09-21 12:24:46.335 INFO 14663 --- [Thread-2] ConfigServletWebServerApplicationContext : Closing org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@6fadae5d: startup date [Fri Sep 21 12:24:21 EDT 2018]; root of context hierarchy
2018-09-21 12:24:46.340 INFO 14663 --- [Thread-2] o.s.j.e.a.AnnotationMBeanExporter : Unregistering JMX-exposed beans on shutdown
2018-09-21 12:24:46.341 INFO 14663 --- [Thread-2] o.s.j.e.a.AnnotationMBeanExporter : Unregistering JMX-exposed beans
2018-09-21 12:24:46.345 INFO 14663 --- [Thread-2] io.undertow.servlet : Destroying Spring FrameworkServlet 'dispatcherServlet'
