Shiny proxy not working after latest docker upgrade
We have updated to the latest version of docker EE: Docker version 17.06.1-ee-2, build 8e43158
After the upgrade, we have followed the instructions: https://www.shinyproxy.io/getting-started/
Afterwards, we get the following error:
Error
Status code: 500
Message: Failed to start container: java.util.concurrent.ExecutionException: javax.ws.rs.ProcessingException: org.apache.http.conn.HttpHostConnectException: Connect to 172.18.0.1:2375 [/172.18.0.1] failed: Connection refused (Connection refused)
Is the following line: ExecStart=/usr/bin/dockerd -H unix:///var/run/docker.sock -D -H tcp://127.0.0.1:2375
not current anymore, or not working with the newest version of docker?
Thanks
Marek
I’m experiencing the same issue with
Docker version 17.06.2-ce, build cec0b72
16.04.3 LTS (Xenial Xerus)
Changing ExecStart variable in the /lib/systemd/system/docker.service file fixed the issue for me.
ExecStart=/usr/bin/dockerd -H fd:// -D -H tcp://127.0.0.1:2375
I faced the same issue. Editing the /lib/systemd/system/docker.service as suggested by Luke_Singham fixed it. Thanks a lot!
Thanks @marekdabek for the report, @Luke_Singham for the fix and @Claas for the confirmation. I have updated the getting started guide at https://www.shinyproxy.io/getting-started/#docker to be in line with the latest Docker versions.
Somehow my Centos 7 with Docker version 17.09.0-ce only works when the old setting was presented.
