Hi all,
I’ve hit a new & potentially reproducible issue - similar to:
but the workaround isn’t working for me with an image built with shiny v1.4.
My Nginx is in front of Shinyproxy, with a config file something like this:
location / {
proxy_pass https://myshinyproxy:8080;
proxy_ssl_trusted_certificate /path/to/ca_cert;
proxy_ssl_certificate /path/to/cert;
proxy_ssl_certificate_key /path/to/key;
proxy_ssl_session_reuse off;
proxy_ssl_protocol TLSv1.2;
proxy_redirect / $scheme://$http_host/;
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
proxy_read_timeout 20d;
proxy_buffering off;
proxy_set_header Host $http_host;
To reproduce:
Launch either openanalytics/shinyapps-demo or openanalytics/shinyapps-template from prebuilt images (I’m guessing shiny <v1.4?)
The CSS etc loads fine.
Then build the same dockerfiles and use these images instead - CSS, js etc all fail to load for me, despite loading fine on a build that isn’t behind Nginx.
Can anyone else replicate this?
Any suggested workarounds, other than the above, or rolling back to something that does work?
Thanks,
Stuart
