I try to set the port as shown below
logo-url: https://www.openanalytics.eu/shinyproxy/logo.png
heartbeat-timeout: 60000
port: 10023
authentication: ldap
admin-groups: scientists
Example: ‘simple’ authentication configuration
However, when I try to run
java -jar shinyproxy-2.6.1.jar
It gives this error
APPLICATION FAILED TO START
Description:
Web server failed to start. Port 9090 was already in use.
Despite of the fact that I gave the port 10023
Hello.
The 9090 port is not used by shinyproxy itself, but by Java. Apparently, you already have something running on java in your system, which means that port 9090 is taken.
You can bypass this by adding the following at the top of your application.yml file:
management:
port: 9091
In this case, we configure shinyproxy to tell java to use 9091 instead of its default port (9090).
Thanks iernicus
Its working now !!
Posting configurations for others to use later!
management:
port: 9092
port: 9001
