I am trying to build a dockerfile for a Euler App to test ShinyProxy via “http://www.shinyproxy.io/deploying-apps/”
Upon using the command sudo docker build -t openanalytics/shinyproxy-template .
I get an error while the build is processing that:
Error: unexpected end of input
Execution halted
The command '/bin/sh -c R -e "install.packages(c('shiny', 'rmarkdown', repos='https://cloud.r-project.org/')" ' returned a non-zero code: 1.
I am curious why I am getting this error as this is the same exact command from the dockerfile.
What can I do to resolve this.
-Thanks
