I am trying to set up Auth0 for authentication but I am getting the below errors when calling back to the Shinyproxy. After reading the forums I have set the server to forward-headers-strategy: native though this does not seem to have resolved this issue and I am hoping someone may have some thoughts to help.
When using simple authentication everything is fine so this is just auth0 SAML related
I’m using v2.4 from the DigitalOcean marketplace.
env file excluding ID & key has:
AUTH0_CALLBACK_URL={link}/callback
COOKIE_SECRET=etcetc
SHINY_HOST=localhost
SHINY_PORT=3838
PORT=8080
saml:
idp-metadata-url: etcetc
app-entity-id: urn:etcetc
app-base-url: {link}
name-attribute: http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress
roles-attribute: http://schemas.auth0.com/shinyproxy_roles
logout-url: etcetc
authentication: saml
The error that stands out is this:
Caused by: org.opensaml.xml.security.SecurityException: SAML message intended destination endpoint did not match recipient endpoint
But I am unsure how to resolve this? the SAML url endpoint is /saml/SSO
Error
Status code: 200
Message: Incoming SAML message is invalid
Stack Trace:
org.springframework.security.authentication.AuthenticationServiceException: Incoming SAML message is invalid
at org.springframework.security.saml.SAMLProcessingFilter.attemptAuthentication(SAMLProcessingFilter.java:105)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:212)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:186)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:155)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:117)
at org.springframework.security.web.header.HeaderWriterFilter.doHeadersAfter(HeaderWriterFilter.java:92)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:77)
at org.springframework.security.saml.metadata.MetadataGeneratorFilter.doFilter(MetadataGeneratorFilter.java:87)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:100)
at org.springframework.boot.actuate.metrics.web.servlet.WebMvcMetricsFilter.doFilterInternal(WebMvcMetricsFilter.java:93)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:91)
at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:160)
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:370)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
at org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:2019)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1558)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1449)
at java.base/java.lang.Thread.run(Thread.java:829)
at org.opensaml.common.binding.decoding.BaseSAMLMessageDecoder.checkEndpointURI(BaseSAMLMessageDecoder.java:217)
at org.opensaml.saml2.binding.decoding.BaseSAML2MessageDecoder.decode(BaseSAML2MessageDecoder.java:72)
at org.springframework.security.saml.processor.SAMLProcessorImpl.retrieveMessage(SAMLProcessorImpl.java:105)
at org.springframework.security.saml.processor.SAMLProcessorImpl.retrieveMessage(SAMLProcessorImpl.java:172)
at org.springframework.security.saml.SAMLProcessingFilter.attemptAuthentication(SAMLProcessingFilter.java:85)
… 77 more
