Shinyproxy authentication failed without error
Hi.
I am having a peculiar problem with shinyproxy authentication. I am currently working on a Linux machine, trying to figure out ins and outs of shinyproxy. When I first set up the shiny proxy, I was able to log in to main screen which shows Hello Application & 06_tabsets. The next step for me to link shinyproxy with docker. So I went to followed the manual, edited file in ~etc/… restarted docker & all that jazz.
I booted up the shinyproxy and BAM! I am unable to log in using the default credentials (tesla - password). There is no “Invalid user name or password.” message like when using incorrect password or username, the webpage just reverts back to the log in screen, as if nothing happened (similar to hitting a refresh button).
Since than, I reverted back the docker settings, pulled the docker image again, tried different ports for the app, downloaded the .jar file again, cleaned & reinstalled the whole docker. Still the same problem.
I’d say it might be a firewall problem, if was not working without problems initially.
Thank you.
Logs:
2019-11-11 14:26:27.414 ERROR 17989 --- [ XNIO-2 task-20] io.undertow.request                      : UT005023: Exception handling request to /login
org.springframework.ldap.CommunicationException: ldap.forumsys.com:389; nested exception is javax.naming.CommunicationException: ldap.forumsys.com:389 [Root exception is java.net.ConnectException: Spojení odmítnuto (Connection refused)]
	at org.springframework.ldap.support.LdapUtils.convertLdapException(LdapUtils.java:108) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.support.AbstractContextSource.createContext(AbstractContextSource.java:355) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.support.AbstractContextSource.doGetContext(AbstractContextSource.java:139) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.support.AbstractContextSource.getReadOnlyContext(AbstractContextSource.java:158) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:357) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:328) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:629) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.LdapTemplate.search(LdapTemplate.java:570) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.security.ldap.SpringSecurityLdapTemplate.searchForMultipleAttributeValues(SpringSecurityLdapTemplate.java:241) ~[spring-security-ldap-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.ldap.SpringSecurityLdapTemplate.searchForSingleAttributeValues(SpringSecurityLdapTemplate.java:166) ~[spring-security-ldap-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at eu.openanalytics.containerproxy.auth.impl.LDAPAuthenticationBackend$CNLdapAuthoritiesPopulator.getGroupMembershipRoles(LDAPAuthenticationBackend.java:190) ~[containerproxy-0.8.3.jar!/:0.8.3]
	at org.springframework.security.ldap.userdetails.DefaultLdapAuthoritiesPopulator.getGrantedAuthorities(DefaultLdapAuthoritiesPopulator.java:210) ~[spring-security-ldap-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.ldap.authentication.LdapAuthenticationProvider.loadUserAuthorities(LdapAuthenticationProvider.java:213) ~[spring-security-ldap-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.ldap.authentication.AbstractLdapAuthenticationProvider.authenticate(AbstractLdapAuthenticationProvider.java:89) ~[spring-security-ldap-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:174) ~[spring-security-core-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:199) ~[spring-security-core-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter.attemptAuthentication(UsernamePasswordAuthenticationFilter.java:94) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:212) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) ~[spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178) ~[spring-security-web-5.0.3.RELEASE.jar!/:5.0.3.RELEASE]
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357) ~[spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270) ~[spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
	at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99) ~[spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200) ~[spring-web-5.0.4.RELEASE.jar!/:5.0.4.RELEASE]
	at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:64) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:94) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
	at eu.openanalytics.containerproxy.util.ProxyMappingManager$ProxyPathHandler.handleRequest(ProxyMappingManager.java:159) ~[containerproxy-0.8.3.jar!/:0.8.3]
	at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77) ~[undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43) ~[undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104) [undertow-servlet-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.server.Connectors.executeRootHandler(Connectors.java:336) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
	at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830) [undertow-core-1.4.22.Final.jar!/:1.4.22.Final]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [na:1.8.0_212]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [na:1.8.0_212]
	at java.lang.Thread.run(Thread.java:748) [na:1.8.0_212]
Caused by: javax.naming.CommunicationException: ldap.forumsys.com:389
	at com.sun.jndi.ldap.Connection.<init>(Connection.java:238) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapClient.<init>(LdapClient.java:137) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapClientFactory.createPooledConnection(LdapClientFactory.java:64) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.pool.Connections.<init>(Connections.java:114) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.pool.Pool.getPooledConnection(Pool.java:136) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapPoolManager.getLdapClient(LdapPoolManager.java:340) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapClient.getInstance(LdapClient.java:1601) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2749) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:319) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:192) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:210) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:153) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:83) ~[na:1.8.0_212]
	at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:684) ~[na:1.8.0_212]
	at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:313) ~[na:1.8.0_212]
	at javax.naming.InitialContext.init(InitialContext.java:244) ~[na:1.8.0_212]
	at javax.naming.ldap.InitialLdapContext.<init>(InitialLdapContext.java:154) ~[na:1.8.0_212]
	at org.springframework.ldap.core.support.LdapContextSource.getDirContextInstance(LdapContextSource.java:42) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	at org.springframework.ldap.core.support.AbstractContextSource.createContext(AbstractContextSource.java:343) ~[spring-ldap-core-2.3.2.RELEASE.jar!/:2.3.2.RELEASE]
	... 71 common frames omitted
Caused by: java.net.ConnectException: Spojení odmítnuto (Connection refused)
	at java.net.PlainSocketImpl.socketConnect(Native Method) ~[na:1.8.0_212]
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[na:1.8.0_212]
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[na:1.8.0_212]
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[na:1.8.0_212]
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[na:1.8.0_212]
	at java.net.Socket.connect(Socket.java:589) ~[na:1.8.0_212]
	at java.net.Socket.connect(Socket.java:538) ~[na:1.8.0_212]
	at java.net.Socket.<init>(Socket.java:434) ~[na:1.8.0_212]
	at java.net.Socket.<init>(Socket.java:211) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.Connection.createSocket(Connection.java:375) ~[na:1.8.0_212]
	at com.sun.jndi.ldap.Connection.<init>(Connection.java:215) ~[na:1.8.0_212]
	... 89 common frames omitted
Seems that you can’t connect to the public ldap from forumsys. One reason is that the server may be down… Since this is just for testing, I suggest you use ‘simple’ authentication (https://www.shinyproxy.io/configuration/#simple-authentication) or your existing LDAP server.
Thanks for reply, Maxim. Sorry, I’ve been dealing with docker issues for a while, so I didn’t get to shinyproxy. It works using ‘simple’ authentication. Thanks!
