I have recently set up an AWS ECS Farget cluster for ShinyProxy and it works perfectly. Very much appreciated all the documentation and help. We were also able to tweak the example to our specific set up which was great.
One last bit that I am trying to figure out. According to the ShinyProcy docs, we can make secrets available to the app container by using ecs-managed-secrets in the application.yml under specs. I have an RDS DB URL as parameter store secret which I added as valueFrom and the name is the environment variable. However this does not seem to be working in my case. The container does not have DB acess after deployment and when checking the specific task definition to the app (sp-) in the console, the JSON does not show secrets having been added. I have also provided the necessery permissions to the app task role but still no success. Do you have any advice what I could be missing?
Very much appreciate the support.
Thank You!
Sorry - nevermind! I just realised that this was a feature available from ShiynyProxy 3.2.0 so just needed to upgrade. Thanks again for all the great stuff!
