Everytime I reboot my server (a Google Compute Engine VM), ShinyProxy doesn’t load properly and I have to restart it.
Performing sudo systemctl status shinyproxy.service shows:
shinyproxy.service - ShinyProxy
Loaded: loaded (/etc/systemd/system/shinyproxy.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Doing a sudo systemctl restart shinyproxy.service gets the package running again. I have tried in both Ubuntu 16.04 and 18.04. I am using a nginx reverse proxy. Here is my java version:
openjdk version "1.8.0_181"
OpenJDK Runtime Environment (Zulu 8.31.0.1-linux64) (build 1.8.0_181-b02)
OpenJDK 64-Bit Server VM (Zulu 8.31.0.1-linux64) (build 25.181-b02, mixed mode)
My /var/log/syslog can be seen here: http://www.emillarsen.com/syslog. Could it be that shinyproxy fails to load because java or docker have not finished loading first? I have installed ShinyProxy from the .deb file. My logging in application.yml is set to:
level:
org.springframework.security.ldap.authentication: DEBUG
org.springframework.security.ldap.userdetails: DEBUG
But the shinyproxy.log file is not created.
