Hello to all,
I use shinyproxy to serve applications in Rshiny. The applications have to connect to a local database. However, I have not found a way to connect directly to the host machine. So I tried to dockerize the db and create a network and used the docker.internal-networking: true
and container-network-connections: my-network
for each app.
Would you have any solutions to either connect directly from shinyproxy to my local db or to fix the db solution in a docker + network.
Thanks
