TLDR: Using Nginx auto proxy (with letsencrypt) and Shinypoxy (docker). Everything works fine over https but app assets don’t load correctrly over https. Help appreciated
I have been playing around with using ShinyProxy (in docker) behind auto nginx-proxy. Everything works fine over http but when I switch to https (with letsencrypt)the shiny app assets stop loading. Example app here
I’ve tried adding the proxy config recommended on the main shinyproxy site as recommended by auto nginx-proxy as a custom config but that hasn’t helped. Full nginx config is here.
I previously had everything working using the recommended config and nginx in docker - so the problem is likely to lie with settings for nginx auto proxy.
Any help would be appreciated as I don’t have much Nginx knowledge and have pretty much run out of ideas (with the last idea being to roll back to manually specifying the Nginx config).
