Hi all,
New to Kubernetes, so please be gentle. Having said that I’ve lost a lot of sleep in the last week trying to configure a GKE cluster (with Istio) to run Shinyproxy (also running within the cluster).
I now have SP working fine with istio proxies injected, mutual TLS enabled & OpenID authentication. Thats a big win, but doesn’t feel like it:
The final part of the puzzle is to successfully launch an app.
The image itself runs fine in a local docker instance, but I get a 500 timeout when I try to launch it via SP on GKE. The sp-pod-* launches and but it can’t communicate.
I’ve noticed no service is created with the application pod when internal-networking=true, and I suspect this is the reason for the failure with Istio enabled. Unfortunately I get equally little success when I try internal-networking=false.
As far as I can work it out, I need to provide a Service to tell istio which port should be used for routing requests to the shiny container. Unless anyone knows another method I need to be able to provide a custom label for all the shiny containers for this service to work - they currently get labelled with sp-pod-[containerID].
Please let me know if I’m missing something obvious here. Another option would be to disable istio-injection for this namespace, but that feels like a backward step. Otherwise I think we need something similar to this commit, but for a custom label instead of a nodeselector:
My Java skills are non-existent. I might try offering a pull request, as it seems very simple to copy this method, though it’d probably be embarrassing…
Thanks for any help/suggestions you can offer.
Regards,
Stuart
