Hi Team,
We are using ShinyProxy (3.2.2) behind IIS with URL Rewrite enabled.
The initial application requests correctly honor the HTTP_X_FORWARDED_PREFIX header and the forwarded path is applied as expected.
However, when requests are redirected to the following ShinyProxy internal endpoints:
/app_proxy/…
/api/proxy/…
/heartbeat
/app_i/…
the HTTP_X_FORWARDED_PREFIX header is not being applied anymore.
Current Behavior (example)
Initial Request (correct):
/APPs/ActiveSession/Shinyapps/app/MyAnalyticsApp/
After redirection (incorrect):
/app_proxy/5d9a4c81-7b33-4a73-83d3-8f0dc4ff7b75/
Expected Behavior
We want all requests to maintain the prefix:
/APPs/ActiveSession/Shinyapps/app_proxy/5d9a4c81-7b33-4a73-83d3-8f0dc4ff7b75/
The goal is to ensure that every call routed through IIS preserves a consistent URL pattern.
Current ShinyProxy configuration (application.yaml)
useForwardHeaders: true
forward-headers-strategy: framework
title: Shiny Proxy
port: 8211
container-backend: docker
authentication: none
context-path: /shinyapps
hide-navbar: true
Question
Is there any ShinyProxy configuration option or recommended setup that ensures internal proxy routes (/app_proxy, /api/proxy, /heartbeat, /app_i) also honor the HTTP_X_FORWARDED_PREFIX header?
Any guidance or best practices for running ShinyProxy behind IIS with URL Rewrite would be greatly appreciated.
Thanks!
Chandra
