Docker startup options
I am trying to get shinyproxy working…
How allow connection to port 2375 on OSX?
regards,
regards,
The Docker configuration parameters can be found by executing docker-machine env
on the Docker host, this will return something like:
export DOCKER_TLS_VERIFY="1"
export DOCKER_HOST="tcp://192.168.99.100:2376"
export DOCKER_CERT_PATH="/Users/youruser/.docker/machine/machines/default"
export DOCKER_MACHINE_NAME="default"
# Run this command to configure your shell:
# eval $(docker-machine env)
In the docker configuration of the application.yml
file, you can then use
cert-path: /Users/youruser/.docker/machine/machines/default
url: https://192.168.99.100:2376
host: 192.168.99.100
port-range-start: 20000
HTH,
I am having trouble as well:
I am also having trouble getting this working. I can get to the the page where the apps are located, but then get errors like:
Failed to start container: java.util.concurrent.ExecutionException: javax.ws.rs.ProcessingException: org.apache.http.conn.HttpHostConnectException: Connect to 192.168.99.100:2375 [/192.168.99.100] failed: Connection refused
I have tried a number of different configurations with no luck. Here are some of things I have done along the way. I am doing this on Mac OS:
Use the command: docker-machine env default
to get my settings
I then took the values from:
And updated my application.yml file to:
url: http://192.168.99.100:2375
Ran the recompile of the jar file
Ran the docker app: docker run -d openanalytics/shinyproxy-demo:latest
This is the simplest and seems closest to what you have suggested. I also tried changing the port on the docker run command: docker run -d -p 3838:2375 openanalytics/shinyproxy-demo:latest
Is there a step I am missing, when I look at the docker container, I see shinyproxy running saying:
shinyproxy::run_01_hello()
Loading required package: shiny
Listening on http://0.0.0.0:3838
Thanks
Ok, Figured it out - Let me do this step by step:
to get my settingsexport DOCKER_HOST="tcp://192.168.99.100:2376"
export DOCKER_CERT_PATH="/Users/rajivshah/.docker/machine/machines/default"
export DOCKER_MACHINE_NAME="default"```
2. Update the application.yml file to:
``` cert-path: /Users/rajivshah/.docker/machine/machines/default
host: 192.168.99.100```
3. Ran the recompile of the jar file `zip -r -Zstore ../shinyproxy-0.3.0.jar *`
4. Then run the java file: `java -jar shinyproxy-0.3.0.jar` (It starts the docker containers when you click on an app)
Many thanks, @rajcs4 for reporting back and glad to hear you have lift off!
For the record: if you put a customized version of the @application.yml@ in the same folder as the .jar file (using the same name, i.e. ‘@application.yml@’), the values will be picked up automatically (and overwrite the default configuration).
Of course, I am trying to set up shinyproxy on mac os, but even with this solution I can’t get it work!!!
sudo docker run -p 3838:3838 openanalytics/shinyproxy-demo R -e 'shinyproxy::run_01_hello()'
Hello Application
or 06_tabsets
Thank you very much for your help!!!
Best regards,
Chris
here comes the rescue, check it out, it should be helpful
