How would I be able to enable SPO to use SSL/TLS
I tried to disable CADDY ACME and add the certs to ShinyProxy, but that did not work.
environment:
SPO_ORCHESTRATOR: docker
SPO_DOCKER_GID: 995
SPO_CADDY_ENABLE_TLS: “true”
SPO_CADDY_ACME: “false”
https:
enabled: true
certificate-file: /opt/shinyproxy-docker-operator/input/shinyproxy.bdx.com.crt
certificate-key-file: /opt/shinyproxy-docker-operator/input/shinyproxy.bdx.com.key
It seems you are using some configuration options that do not exists.
You can find the correct configuration for custom TLS certs here: Docker | ShinyProxy
It could also be useful to have a look at the structure of the input directory: Docker | ShinyProxy
So your configuration becomes:
SPO_DOCKER_GID: 995
SPO_CADDY_ENABLE_TLS: "true"
realm-id: my-realm
# make sure to not indent these options, these should sit at the highest level in the config file
caddyTlsCertFile: /opt/shinyproxy-docker-operator/input/shinyproxy.bdx.com.crt
caddyTlsKeyFile: /opt/shinyproxy-docker-operator/input/shinyproxy.bdx.com.key
Thanks for the reply.
I tried the approach from Using custom certificates
The issue is that the domain bdx.com can’t be resolved because it is private.
GPT 5.4 was giving all sorts of bad ideas.
The simple question is if I have my own key and crt how can I use them and not have CADDY try to resolve the host or use Let’s Encrypt?
This is what sudo docker logs -f sp-caddy is showing
{“level”:“error”,“ts”:1775658569.9199247,“logger”:“http.acme_client”,“msg”:“validating authorization”,“identifier”:“shinyproxy.bdx.com”,“problem”:{“type”:“urn:ietf:params:acme:error:dns”,“title”:“”,“detail”:“DNS problem: NXDOMAIN looking up A for shinyproxy.bdx.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for shinyproxy.bdx.com - check that a DNS record exists for this domain”,“instance”:“”,“subproblems”:},“order”:“https://acme-staging-v02.api.letsencrypt.org/acme/order/281211673/35805832883",“attempt”:1,"max_attempts”:3}
If you specify the caddyTlsCertFile and caddyTlsKeyFile options, the operator use these certs and will no try to use let’s encrypt.
If it still doesn’t work, could you share your full configuration file?
localhost.shinyproxy.yaml
spring:
session:
store-type: redis
store-mode: Redis
stop-proxies-on-shutdown: false
realm-id: localhost
- name: jack
password: password
groups: scientists
- name: jeff
password: password
groups: mathematicians
- id: 01_hello
container-cmd: [ “R”, “-e”, “shinyproxy::run_01_hello()” ]
access-groups: [ scientists, mathematicians ]
- id: 06_tabsets
container-cmd: [ “R”, “-e”, “shinyproxy::run_06_tabsets()” ]
access-groups: scientists
image: openanalytics/shinyproxy:3.2.3
fqdn: shinyproxy.bdx.com
forward-headers-strategy: native
docker-compose.yml
services:
shinyproxy-operator:
image: openanalytics/shinyproxy-operator:2.3.1
environment:
SPO_DOCKER_GID: 995
volumes:
- ./input:/opt/shinyproxy-docker-operator/input
- /var/run/docker.sock:/var/run/docker.sock:ro
- /opt/shinyproxy-docker-operator/data:/opt/shinyproxy-docker-operator/data
group_add:
- 995 # replace by the id of step 6
networks:
- sp-shared-network
restart: always
labels:
app: shinyproxy-operator
user: “1001”
networks:
sp-shared-network:
Thanks for looking. It works without TLS and I know the certs are good.
Hi, the caddyTlsCertFile are top-level configuration options, so they should be put outside the proxy configuration block (see my example in my previous post).
Your configuration becomes:
spring:
session:
store-type: redis
store-mode: Redis
realm-id: localhost
- name: jack
password: password
groups: scientists
- name: jeff
password: password
- id: 01_hello
- id: 06_tabsets
I’ll make the documentation on this setting a bit more clear.
