ShinyProxy with Keycloak gives NullPointer Exception
Hi.
We have ShinyProxy running behind a Nginx proxy using Keycloak for authentication. The authentication seems to work correctly and the screen with the Shiny app links is also shown correctly. When starting one of the Shiny apps the first time, the app loads and works. However, when opening the same app a second time or starting another app, then ShinyProxy gives a NullPointer exception:
Error
Status code: 500
Message:
Stack Trace:
java.lang.NullPointerException
at eu.openanalytics.services.DockerService.findProxy(DockerService.java:432)
at eu.openanalytics.services.DockerService.getMapping(DockerService.java:192)
at eu.openanalytics.controllers.AppController.app(AppController.java:49)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:116)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:85)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.adapters.springsecurity.filter.KeycloakPreAuthActionsFilter.doFilter(KeycloakPreAuthActionsFilter.java:84)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:64)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99)
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:105)
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:81)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:211)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:809)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.base/java.lang.Thread.run(Thread.java:844)
The logs show the following:
2018-04-03 21:14:48.511  INFO 7670 --- [XNIO-2 task-3] eu.openanalytics.services.UserService    : User logged in [user: null]
2018-04-03 21:14:48.599  INFO 7670 --- [XNIO-2 task-4] io.undertow.servlet                      : Initializing Spring FrameworkServlet 'dispatcherServlet'
2018-04-03 21:14:48.599  INFO 7670 --- [XNIO-2 task-4] o.s.web.servlet.DispatcherServlet        : FrameworkServlet 'dispatcherServlet': initialization started
2018-04-03 21:14:48.621  INFO 7670 --- [XNIO-2 task-4] o.s.web.servlet.DispatcherServlet        : FrameworkServlet 'dispatcherServlet': initialization completed in 22 ms
2018-04-03 21:14:51.460  INFO 7670 --- [XNIO-2 task-8] c.s.docker.client.DefaultDockerClient    : Creating container with ContainerConfig: ContainerConfig{hostname=null, domainname=null, user=null, attachS
tdin=null, attachStdout=null, attachStderr=null, portSpecs=null, exposedPorts=[3838], tty=null, openStdin=null, stdinOnce=null, env=[SHINYPROXY_USERNAME=null, SHINYPROXY_USERGROUPS=UMA_AUTHORIZATION,USERS]
, cmd=[R, -e, shiny::runApp('/root/fhnw')], image=fhnw/shinyapp, volumes={}, workingDir=null, entrypoint=null, networkDisabled=null, onBuild=null, labels=null, macAddress=null, hostConfig=HostConfig{binds=
[], blkioWeight=null, blkioWeightDevice=null, blkioDeviceReadBps=null, blkioDeviceWriteBps=null, blkioDeviceReadIOps=null, blkioDeviceWriteIOps=null, containerIdFile=null, lxcConf=null, privileged=null, po
rtBindings={3838=[PortBinding{hostIp=0.0.0.0, hostPort=20000}]}, links=null, publishAllPorts=null, dns=null, dnsOptions=null, dnsSearch=null, extraHosts=null, volumesFrom=null, capAdd=null, capDrop=null, n
etworkMode=null, securityOpt=null, devices=null, memory=null, memorySwap=null, memorySwappiness=null, memoryReservation=null, cpuPeriod=null, cpuShares=null, cpusetCpus=null, cpusetMems=null, cpuQuota=null
, cgroupParent=null, restartPolicy=null, logConfig=null, ipcMode=null, ulimits=null, pidMode=null, shmSize=null, oomKillDisable=null, oomScoreAdj=null, autoRemove=null, pidsLimit=null, tmpfs=null, readonly
Rootfs=null, storageOpt=null}, stopSignal=null, healthcheck=null, networkingConfig=null}
2018-04-03 21:14:51.767  INFO 7670 --- [XNIO-2 task-8] c.s.docker.client.DefaultDockerClient    : Starting container with Id: 2f5156318c14cafade0ef9bfd583abd61faf47727c0e13bc6e37ca1a84f535bd
2018-04-03 21:14:54.374  WARN 7670 --- [XNIO-2 task-8] eu.openanalytics.services.DockerService  : Container unresponsive, trying again (2/10): http://localhost:20000
2018-04-03 21:14:58.291  INFO 7670 --- [XNIO-2 task-8] eu.openanalytics.services.DockerService  : Proxy activated [user: null] [app: kmumonitor] [port: 20000]
2018-04-03 21:15:04.746 ERROR 7670 --- [XNIO-2 task-10] io.undertow.request                      : UT005023: Exception handling request to /app/kmumonitor
For the moment the only significant observation we made, is that the user is null. Using simple file based authentication everything works as expected and the variable user is showing to be non-null in the logs.
Any help would be greatly appreciated.
Best regards
Adrian
Hi @Adrian_Trapletti,
Thanks for the report. What version of ShinyProxy are you using? In version 1.1.0 a fix was introduced that specifically rejects logins in case the keycloak token contains a null name. See https://www.shinyproxy.io/downloads/
Hope this helps!
Hi @tverbeke
Thanks for the answer. I used version 1.0.2.
In the meantime I upgraded to 1.1.0, but now the Keycloak login screen appears, but after login, it’s not redirecting back to ShinyProxy as it should, but I get a “too many redirect” error. I tried a number of configurations, so far no success. The latest Nginx configuration includes the following
location /auth/ {
proxy_pass http://127.0.0.1:8087/auth/;
   proxy_http_version 1.1;
   proxy_set_header Host $host;
with Keycloak on port 8087, the latest ShinyProxy configuration includes
keycloak:
  realm: shinyproxy
  auth-server-url: https://somehost.com/auth
  resource: shinyproxy
  credentials-secret: some-secret
useForwardHeaders: true
and in Keycloak I use the usual settings plus https://somehost.com/* for the ‘valid redirect uri’, for ‘require ssl’ the ‘external requests’ option and for ‘client authenticator’ the ‘client id and secret option’.
Any idea of what’s going wrong with this configuration?
Best regards
Adrian
Could you try using a tool to inspect the requests happening when you try to authenticate?
The response from shinyproxy that sends the user to keycloak, should include a header with a redirect uri. That value should match the ‘valid redirect uri’ that you configured in keycloak.
Can you verify that this is the case?
To know more about NullPointer Exception go to https://errorcode0x.com/resolve-steam-error-code-80/ and learn about it.
