String index out of range: 12
I recently updated shinyproxy from 2.5.0 to 3.0.2. As well I updated the custom templates.
I can sign-into the index.html page that displays the list of apps to launch. But I can only launch the first app. Where the others fail.
For some context, we have shinyproxy set up in a container and deployed as a docker swarm.
full java error:
eu.openanalytics.containerproxy.ProxyFailedToStartException: Container with index 0 failed to start
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.startProxy(AbstractContainerBackend.java:116) ~[containerproxy-1.0.2.jar!/:1.0.2]
at eu.openanalytics.containerproxy.service.ProxyService.startOrResumeProxy(ProxyService.java:455) [containerproxy-1.0.2.jar!/:1.0.2]
at eu.openanalytics.containerproxy.service.ProxyService.lambda$startProxy$4(ProxyService.java:279) [containerproxy-1.0.2.jar!/:1.0.2]
at eu.openanalytics.containerproxy.service.ProxyService.lambda$action$11(ProxyService.java:599) [containerproxy-1.0.2.jar!/:1.0.2]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[na:1.8.0_342]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[na:1.8.0_342]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[na:1.8.0_342]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[na:1.8.0_342]
at java.lang.Thread.run(Thread.java:750) ~[na:1.8.0_342]
Caused by: eu.openanalytics.containerproxy.ContainerFailedToStartException: Docker swarm container failed to start
at eu.openanalytics.containerproxy.backend.docker.DockerSwarmBackend.startContainer(DockerSwarmBackend.java:221) ~[containerproxy-1.0.2.jar!/:1.0.2]
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.startProxy(AbstractContainerBackend.java:108) ~[containerproxy-1.0.2.jar!/:1.0.2]
… 8 common frames omitted
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: 12
at java.lang.String.substring(String.java:1963) ~[na:1.8.0_342]
at eu.openanalytics.containerproxy.backend.docker.DockerSwarmBackend.calculateTarget(DockerSwarmBackend.java:233) ~[containerproxy-1.0.2.jar!/:1.0.2]
at eu.openanalytics.containerproxy.backend.AbstractContainerBackend.setupPortMappingExistingProxy(AbstractContainerBackend.java:248) ~[containerproxy-1.0.2.jar!/:1.0.2]
at eu.openanalytics.containerproxy.backend.docker.DockerSwarmBackend.startContainer(DockerSwarmBackend.java:217) ~[containerproxy-1.0.2.jar!/:1.0.2]
… 9 common frames omitted
I ran sudo service docker status and got an error saying “invalid mount config for type “bind”: bind source path does not exist”
Long story short, I had the volume paths wrong. Once I fixed this, all the apps launch now.
