So, I’m working in a CentOS7 and I just installed ShinyProxy using the .rpm file (https://www.shinyproxy.io/downloads/).
The problem is that I want to configure the ShinyProxy, but I can’t find the installation folder or similar to create (or modify) the application.yml.
I know that using the platform-independent .jar I’m able to create the application.yml file in the folder where the .jar is executed, but I don’t know where I have to create the application.yml to configure ShinyProxy if the program was installed using the .rpm.
Hope you can help me.
