I want to use a a proxy for my app. The problem is that I use urls bookmark too, and I can’t add some urls to the proxy because even if it the only app the landing page is on the list of app.
Moreover I don’t want the app on the / page, but on the /padle/.
This is my shinyproxy configuration.
servlet:
context-path: /padle
authentication: none
container-log-path: /var/log/shinyproxy/container-logs
hide-navbar: true
bind-address: 127.0.0.1
internal-networking: false
cert.pem: /etc/apache2/ssl/padle_sophia_inrae_fr_cert.cer
key.pem: /etc/apache2/ssl/padle.key.pass
- id: padle
display-name: PADLE
description: Profiling Anaysis of DifferentiaL Expression
container-cmd: ["R", "-e", "options(golem.app.prod = T); padle::run_app()"]
container-image: padle
# server:
# forward-headers-strategy: native
level:
root: INFO
When I use landing page = /app/padle with the context path, I am landing on the page /app/padle and not /padle/app/padle, so there is an error. If I set landing page to /padle/app/padle, there is an error too.
This is my config nginx :
location /padle/ {
proxy_pass http://127.0.0.1:8080;
# proxy_redirect http://127.0.0.1:8080 http://127.0.0.1:8080/padle/app/padle/$1;
proxy_http_version 1.1;
proxy_read_timeout 600s;
proxy_redirect off;
proxy_set_header Host $http_host;
If I uncomment proxy redirect, the app doesn’t launch and redirect to the list of the app. I try to set the context-path to / but there is 404 error.
I try to use this, with context path set to / and /padle :
location ~ ^/padle/(.*)$ {
proxy_pass http://127.0.0.1:8080/padle/app/padle/$1;
# Or proxy_pass http://127.0.0.1:8080/app/padle/$1;
With nothing than error 404.
When I look in the error file for nginx, i see [error] 13686#13686: *292 connect() failed (111: Connection refused) while connecting to upstream
this error message, for this configuration (http://127.0.0.1:8080/padle/app/padle/$1
, context-path=/padle and landing-page=/)
I need help, please, also, but this a bonus, I want to have an clean url in the browser, so a thing like this /padle/values=… .
The version of shinyproxy I use is 2.5.0.
Thanks,
Regards,
Arthur
